Using 2 CS400's in 7.1 setup
Polkie2009
Polkie2009 Posts: 3,834
edited June 2009 in Speakers
Just a newbie here, I think I've seen on here where someone wanted to run 2 CS400's up front for their center channel. Has anyone tried running a pair of these as mains, surrounds or back speakers?
Post edited by Polkie2009 on
  • Kex
    Kex Posts: 5,219
    edited June 2009
    Huh?! Why? What would be the advantage, compared to two RT55 or RT800 etc. instead?
    Oh, and welcome to CP, BTW!
    Alea jacta est!
  • messiah
    messiah Posts: 1,790
    edited June 2009
    +1. Not sure what the advantage would be. Also, welcome to the forum.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • polkie4life
    polkie4life Posts: 231
    edited June 2009
    Polkie2009 wrote: »
    I tried this a few years ago and swapped a rt55i out for my cs400i. The results were quite horrible really! I dont know really how to describe it but put it down to the dispersion of sound the 400i puts out. It was great trying it but it just sounded wrong...
    In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
    http://www.polkaudio.com/forums/showcase/view.php?userid=86838
  • EniGmA1987
    EniGmA1987 Posts: 3
    edited June 2009
    my guess would be that you would lose a lot of channel separation, but gain coverage area. So if you had a really big room it might have more advantages than disadvantages. But for most situations I would be a single center channel would work better.
  • Polkie2009
    edited June 2009
    Thanks for the info, I had a feeling someone has tried using 2 CS400's before as mains or surrounds. I have a Yamaha RX-V663 7.2 AVR and was thinking if I could run a single CS400 as a back speaker in a 6.1 setup? I'll still be using another CS400 up front for a center speaker. Mains up front are the SDA-SRS 2s.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    Welcome to Club Polk Polkie2009 & EniGmA1987!
  • Airplay355
    Airplay355 Posts: 4,298
    edited June 2009
    If you're powering your center off your receiver maybe you should grab an amp for the center channel. More speakers might not work but more power would.
  • Polkie2009
    edited June 2009
    Thanks for the welcom hearingimpared,lol.This is a great forum! I'm looking into getting a 2 or 3 channel power amp to feed the big fronts since my AVR has the outputs to do that. I've read here how they come alive when you feed them over 200 wattsRMS per channel. I've got some big pro audio amps(crest, carvin) that put about 400wattsRMS per channel at 8 ohms. I've read mixed results when using the pro audio amps dealing with 60 hz. hum,ground loops,fan noise, etc.
  • Kex
    Kex Posts: 5,219
    edited June 2009
    Polkie2009 wrote: »
    Your OP has two questions, really.
    1) Using CS400 as mains.
    2) Using two CS400 centers, instead of one.
    For the first point, you have answers already. For the second point, if you want a rear center for 6.1, I'm not very familiar with 6.1 so I'm not sure what type of speaker is considered preferable for the center "surround back" position. My initial reaction is to question whether a CS400 rear center would be better than a third standard speaker, identical to the two other surround speakers, but it seems like it should at least work, if you had some reason for wanting it that way.
    You may have to do some more research on this before deciding, or wait for someone with more knowledge of this less common surround format.
    Alea jacta est!
