stain for rti a speekers
superjunior
superjunior Posts: 1,632
edited June 2009 in Troubleshooting
does anyone know what stain would match the rti a speekers? I bought a set of a9's a while back and they were slightly damaged in shipping. The seller agreed to pay for the repair, so I had a carpenter come over and patch the wood. Didn't realize that was the easy part, this poor guy has been over 6 or 7 times the last couple weeks trying to match the color just right- no luck. Does polk sell a touch up stain? Any help is greatly appreciated. thanks
jr
panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
Post edited by superjunior on
    F1nut Posts: 50,734
    edited June 2009
    Was the guy actually a carpenter or a cabinet maker or a restorer? What did he use to fix the damage? What is he trying to use to match the color?
  • superjunior
    edited June 2009
    he's a general contractor that does home improvement type work. he used wood putty to fill the gouges. After sanding them they look perfect (besides the color). He's been trying to match the color with different shades of miniwax stain. We've tried a bunch of different shades including cherry, so far the closest match is a color called sedona red. close but not exact. thanks ahead for any advice Jesse
    Dan
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
    F1nut Posts: 50,734
    edited June 2009
    OK, wood putty is fine if you're going to paint over it, but it's not the best choice when working with a translucent color. Wood epoxy is a better choice, comes in a clear plastic tube and kind of looks like a Tootsie roll, but I don't think you'll find at the hardware store. Anyway, too late for that now.
    Because wood putty or wood epoxy absorb color differently than actual wood, you'll never get a stain in a can to match the original color. What you need is a furniture touch up guy to work on them. He will have all the right stuff and if he's good, will be able to blend those repairs so that they pretty much disappear. Look in your Yellow Pages under furniture repair, etc.
    It's time to let the general contractor off the hook.
  • superjunior
    edited June 2009
    thanks f-1. I don't know if it's too late yet, the putty could be sanded back out and re-done. I was a little sceptable(sp?) about the putty he was using. The holes are fairly small, the bigger one about the size of a nickel. I hate to make the guy re-do it, but he will as he knows I'm ANAL about this project. I'd hate to fire him , he's already got a bunch of time involved and is willing to do whatever it takes to get these right. He's a freind of a freind and giving me a pretty good deal.
    jr
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
    F1nut Posts: 50,734
    edited June 2009
    Dan, there's no point in trying to redo the repairs, that always ends up being a bigger mess than what you started with. I'm sure the guy means well and no slight on him, but he doesn't have the knowledge or materials needed for the job. Pay and thank him for his time, then find someone that does furniture touch up/repairs for a living.
  • superjunior
    edited June 2009
    I was trying to avoid it, but your right. Gonna follow your advice. Thanks man
    Dan
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • messiah
    messiah Posts: 1,790
    edited June 2009
    You might consider an upgrade. You can buy wood verneer in very thin (almost paper thin) sheets, and in exotic woods for relatively little money. You could make those speakers look really cool!! I think Vr3mxstyler2k3 did that once.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • superjunior
    edited June 2009
    that sounds like an interesting project
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited June 2009
    messiah wrote: »
    Sweet, zebra stripe those A9's, lol.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2009
    Now that would look killer, maybe I should do that with the RTi12s. Where can you buy the material?
  • messiah
    edited June 2009
    Locally by me there is Owl Lumber, but I know there are several online resourses for exotic verneers and they don't even have to cost that much. I'll check it out and get back to you. BTW ask Sid, from what I remember seeing he did a kick **** job!!
  • superjunior
    edited June 2009
    I sure like to see some pics of that
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Jim Shearer
    Jim Shearer Posts: 369
    edited June 2009
    Here's where I have been buying veneer:
    http://www.tapeease.com/products.htm
    I like the peel & stick veneer. Just make sure that the surface is smooth--all the dings filled. Then it needs to be finished; I like polyurethane, but have used Minwax Polycrylic. I don't know if it would stick to an oil finish.
    Cheers, Jim
    A day without music is like a day without food.
