center speaker
DAVIDDOWENS
DAVIDDOWENS Posts: 1
edited June 2009 in Troubleshooting
My center speaker works fine with tv and some dvd's. But when playing action movies, their seems to be a popping noise. It really isn't that loud. What to do?
Post edited by DAVIDDOWENS on
    nooshinjohn Posts: 25,891
    edited June 2009
    what Kind of center is it?
  • McLoki
    McLoki Posts: 5,231
    edited June 2009
    If you switch the wires between one of your front speakers and your center, does the problem stay with the speaker or stay with the channel?
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2009
    Could be a lot of things. Try what McLoki says and swap one of your fronts with the center and see what happens.
    Not knowing you system I would guess you are overdriving the center. I.E. not enough power from your amp to reproduce the sound at the level you are asking from your AVR.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    Or your center is set to large when it should not be.
    Please give us an idea of what is in your system.
    Main Surround -
