Martin Logan Depth i or SVS PC13 Ultra?
The title says it all. The sub will blend with 2 LSi25 subs and I am 80% music 20%HT. I can have them for same price but I still don't know which one I am going to buy.
Living room
Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
Player: Oppo 95.
Amps: Bryston 4B SST, B&K Ref 200.7 S2.
Pres: B&K Ref 50 S2, Paraound P5.
Subs: Dual Rythmik F15HP subs.
Man Cave
Speakers: Martin Logan Vistas.
Player: OPPO 105.
Preamp: B&K Ref 50 S2.
Amp: B&K Ref 125.2 S2
Sub: Rythmik F12.
Sub management: SMS-1.
Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
Room treatment: GIK Room Kit #1.
Post edited by suprafantx on
  • polkmeister
    polkmeister Posts: 26
    edited June 2009
    Consider a Epik Dynasty. I have 4X LSi15s Front & Surrounds, an LSiC Center, and vintage Model 10's in the rear... all on top of the Dynasty "foundation". Really really happy... totally awesome low end. Keep the spackling compound handy.:cool:
    ______________________________
    F: 1pr LSi15's ebony
    C: LSiC
    Surr: 1pr LSi15's ebony
    Surr,R: 1pr LSi9's ebony
    Sub: Epik Dynasty
    Outside: 4x Atrium 65SDI
    Legacy Remotes (pristine): 1pr Polk 10's, 3pr Polk 7's
    AVR: Onkyo TX-SR806
    PA's: 6x NAD2400
    Video: Sony KDL-52XBR6
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2009
    Svs.
  • dpowell
    dpowell Posts: 3,081
    edited June 2009
    SVS would be my choice.
  • bevo
    bevo Posts: 306
    edited June 2009
    I have the pb 13 ultra, and it is great. I imagine though, since you are 80% music, there might be a better choice somewhere for you.
    Don't get me wrong, the ultra sounds good with music, but it doesn't really give the thump of a bass drum like you would expect. It's not really, really tight like I would want if my main use was for music.
    For home theater though, it will blow your mind. I was never a really big movie guy, but since getting the ultra I can't watch enough of them. It will literally almost make you sick to the stomach with some of it's low bass. The incredible hulk has a scene where it has waves of 15 hz bass that you can't hear but you can feel the pulses running through you.
    The ultras are great subs, but for some reason I think that you could do better for music.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    Martin Logan Depth i would be better for Music.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • speakergeek
    speakergeek Posts: 555
    edited June 2009
    bevo wrote: »
    Have you tried sealed mode?
  • mantis
    mantis Posts: 17,570
    edited June 2009
    The Martin Logan is a much better musical subwoofer. It will do Movies extremely well, it does not have the sheer impact of a SVS sub but does it with better control and quickness. I feel the Martin logan is much easier to tune into a system. It goes away. It becomes apart of the system.
    Go Martin Logan
    Dan
    Dan
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2009
    Just my opinion...
    Every SVS I have heard (so far) sounds like an insane thunderous slam. Just dominates the room and shakes everything.
    In comparison, on my Dayton Titanic you cannot even tell if it's on. It blends very well and does not dominate the room.
    I would go SVS for movies, ML for music.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • daboyz
    daboyz Posts: 5,207
    edited June 2009
    I must agree with Dan. I've loved my Depth. It is very musical and as he says it just molds into your system.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited June 2009
    I haven't heard the SVS so I can't comment on that, but I have heard plenty of Martin Logan subs (including the depth) and they are wonderful, especially for music. If I were listening to my system 80% music, I wouldn't hesitate to buy the Martin Logan.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2009
    Haven't heard the Depth and I agree the Ultra13 can easily dominate the rig...a good thing for HT effects, but overwhelming for music. I've experiemented quite a bit with it to tame some of that. It's really quite transparent and not heavy handed at all if calibrated correctly at the crossover, run cold vs hot, so that the bass reinforces the mains...and...if you seal it, scrub the room gain, and get a more or less flat response, it exhibits all the best qualities of other high end sealed subs. One of the reasons it's got so many flexibility options is (da-da) that it's flexible. Take the time with it and you won't be disappointed. I've been running mine sealed for a few months with great results, butya no, this weekend I unsealed it and am running in 20hz tune since I've been watching a bunch of new BDs on my new Oppo. It's still musical, but sealed is better, though HT is more fun. I've compared it to Velo DDs and Rythmik sealed subs. Other than being more powerful, it doesn't take a back seat in SQ to either. Rooms and calibration issues are usually the culprits, not this sub.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • bevo
    bevo Posts: 306
    edited June 2009
    Ron Temple wrote: »
    I still haven't tried mine sealed yet. I guess I shouldn't have commented on the SVS not being musical, until I have tried it sealed. In all honesty, I was so overwhelmed by it in the 20hz tune, I forgot you could change it. I think this weekend I will try and give it a shot sealed and see how it sounds.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • bassfann
    bassfann Posts: 151
    edited July 2009
    the svs subs are great for music and ht,its the way to go
  • suprafantx
    suprafantx Posts: 249
    edited July 2009
    Thanks for inputs and advices to all. I pulled the trigger on ML and it is the best music sub I have ever owned. I am in heaven with music now.:p
    Living room
    Player: Oppo 95.
    Man Cave
    Player: OPPO 105.
    Sub: Rythmik F12.
