surroundbar 360
ctv4f
Hi, a have a surroundbar 360dvd, I have some trouble to find one radio station example the station is 96.9fm and when I search I see 96.8 , 97.0 twice and then 97.1, it does not catch 96.9why? i tried to turn the main power off and on same thing.
thanks
john
thanks
john
Post edited by ctv4f on
I have no knowledge on the 360 and maybe only a little more on radio. When you say "search" are you referring to the seek feature? All I can guess at is maybe 97.0 is very strong and 96.9 a week signal.
Can you manually tune it to 96.9 and get anything? Do you know where the towers are located for 96.9 and 97.0?
Hopefully Polk CS or someone that knows something about radio broadcasting can help you out.
Welcome to CP
