more power
royalty
royalty Posts: 246
edited June 2009 in Troubleshooting
So I have an onkyo 706 and I also have this older sony receiver that I dont use. I was wondering if I could use the onkyo to power my center and two fronts and then use it as like a pre amp and connect it to the sony receiver and use the sony receiver to power the two surrounds. Is this possible?
HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
Post edited by royalty on
    F1nut Posts: 50,734
    edited June 2009
    No.
  • royalty
    royalty Posts: 246
    edited June 2009
    the manual says the receiver can function as a pre amp and can be hooked up to a power amplifier....the sony receiver cannot be used as and amplifier?
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    F1nut Posts: 50,734
    edited June 2009
    Nope.
  • royalty
    royalty Posts: 246
    edited June 2009
    ok thanks
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
  • McLoki
    McLoki Posts: 5,231
    edited June 2009
    The Onkyo would put out more power driving 5 speakers than the Sony would driving 2 speakers anyway.....
    If you really want more power, sell the sony and get an older 2 channel amp for a few hundred $ to run your front speakers off of. If not - don't worry about it and rock on.
    To directly answer your question, you may be able to make the sony work with the Onkyo but I cannot think of a situation that would make it worth while to even try.
    Michael
  • Systems
    Systems Posts: 14,873
    edited June 2009
    McLoki wrote: »
    Exactly.It can be done but it's not worth doing.
    Testing
    Testing
    Testing
  • dpowell
    dpowell Posts: 3,068
    edited June 2009
    It would also be frustrating since you would always be having to adjust two separate volume control knobs. +1 on the advice above. Save your $$ and work towards getting a separate amp.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • ctv4f
    ctv4f Posts: 2
    edited June 2009
    Hi, a have a surroundbar 360dvd, I have some trouble to find one radio station example the station is 96.9fm and when I search I see 96.8 , 97.0 twice and then 97.1, it does not catch 96.9why? i tried to turn the main power off and on same thing.
    thanks
    john
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited June 2009
    ctv4f wrote: »
    thanks
    john
    I have no experience with the Surroundbar, but thread jacking isn't the best way to find an answer, lol. Try re-posting in your own thread and you will get more/better responses. Welcome to Club Polk.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • royalty
    royalty Posts: 246
    edited June 2009
    haha too funny
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    Wow threadjacked.
    I bet you could do it, but it would sound horrible once you get it set up, and you'd just dismantle it.
    Main Surround -
