Polk DSW Pro subs
kevhed72
kevhed72 Posts: 5,064
edited June 2009 in Troubleshooting
What are the ROUGH room size guidelines for choosing between a 400, 500, and 600 series of this Polk sub. Use would be HT, and only running a single sub. at this time. please advise...
(current setup - RTiA9s, CSiA6, FXiA6; 5.1 HT setup)
Post edited by kevhed72 on
    Toolfan66 Posts: 17,329
    edited June 2009
    Get the 600.... With your current setup for HT the 600 is ideal. I have the same setup as you for the most part but i am running 7.2 I have the FXiA6's on the sides and rears and i also have the DSW 600 and DSW 500.
    Go with the 600 and don't look back.
    Larry.
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
    edited June 2009
    Go to go with Larry on this!
    A9s can put out some BASS...so the largest of that series IS necessary! You'll be happy.
    cnh
  • kevhed72
    edited June 2009
    Thanks for talking me out of trying to "cheap-out" on the sub...there are a few 600's on Ebay right now....
