home computer speakers
Judy123
Judy123 Posts: 1
edited June 2009 in Troubleshooting
I have 2 older, very basic polk audio speakers used with my 6 year old HP home computer. Just bought new HP and can't get the volume up to where I can hear it without holding the speakers to my ears. Any suggestions - :confused:
Post edited by Judy123 on
  • mshan242700
    mshan242700 Posts: 823
    edited May 2009
    Are the Polk speakers self-amplified? (if not, you probably need an integrated amp or receiver to drive the Polks; your computer only provides a line level output).
    If you have an amp for the speakers, check the sound mixer tab on your computer and make sure the WAV setting is set at 100%.
  • Eric W
    Eric W Posts: 556
    edited June 2009
    If those speakers originally came with an HP Pavilion computer, they are only compatible with that computer. The amplifier was inside the computer, this is why the volume is very low when you try it out on a different computer. The only solution is to get new computer speakers.
    -Eric
    -Polk Audio
  • mizthuphee
    mizthuphee Posts: 55
    edited June 2009
    if I were you, i would invest on a used/new integrated amp & DAC (a must). Check out this dac http://www.emu.com/products/product.asp?category=610&subcategory=611&product=18388, I have not used it but i've read good things about it. for my set up, i have: imac>itunes (AIFF)>dac>HCT (ipod tube thingee)>rti4. pretty happy with it.
    HT / 2 Channel combo system:
    LSi9 (xo modified by Face), LSiC, LSi-FX
    Mac mini 2010 boot up in 64 bit kernel (2.66 GHz 8GB RAM,60 GB SSD)>itunes> 2TB mini Stack v3>Pure Music>W4S DAC2>Conrad-Johnson PV14>W4S SX1000
    oppo BDP 85SE
    Onkyo TX-SR876
    Emotiva XPA-5
    HSU VTF-1
    Samsung LN4095D
    MIT S3 speaker cables (LR & C) & interconnects
    MIT EXP 2 (L & R surrounds)
    Pangea PC A-9's and A-14SE's
