Monster HTS5000 buzz alarm
Tomasito
Tomasito Posts: 142
edited June 2009 in Troubleshooting
Hello,
Suddenly this morning my HTS5000 gave a buzzin audio alarm. It did not show any power.
I followed the owners manual to press reset the 15A breaker at the back wait for 10 minutes before powering up. I followed the instructions did this a number of times. It did not fix the problem.
I opened the HGTS5000, and checked the fuse for continuity, the fuse is good
can anybody advise me what to check, or is the HTS5000 fried?
Thanks in advance
Post edited by Tomasito on
  • AKofD1
    AKofD1 Posts: 1
    edited June 2009
    Same thing happened to mine last night. Buzzing noise, 2 left green lights on only and nothing works. Did you get an answer or figure how to reset?
    thanks
    AK
