Pioneer MCACC
Pedler
Pedler Posts: 95
edited May 2009 in Electronics
Just curious how many of you pioneer users like the sound that the MCACC
performed?
I have tried it many times and don't like how it EQ's my speakers.:(
Have you given up and manually done it, or have you used certain parts of it.
Post edited by Pedler on
  • Pedler
    Pedler Posts: 95
    edited May 2009
    I even think out of the box default off it sounds better.
    I have Given up and 10 min in to EQ-ing, it sounds better than the MCACC.
    Toolfan66 Posts: 18,069
    edited May 2009
    I used it, and i like it. the only thing i did after was set my front stage to large, and readjusted the db on my front stage.
  • mantis
    mantis Posts: 17,424
    edited May 2009
    What I'm going to assume here if you never heard a properly calibrated system is the reason why most of you are not liking the mcacc results.
    1st off I suggest you try to consider the room you are placing your system in. Is the speakers in there proper places? Do you know what the standard is vs where you have to place your speakers in your room? Most living space rooms are not even close to ideal for a theater system to perform correctly. There are many challenges that will ruin your systems performance. Mcacc will try to correct some of those problems and get you as close as possible.
    Proper placement of the mic is very important. And when you run mcacc , there can't be ANY noise. Anything that can be heard will throw off the calibration.
    Most people get uncomfortable with where or what size a speaker should be set at. For home theater 99% of speakers out there should be set to small and crossed over near it's low bass extention. Let the sub do everything under 80hz unless you have very good low clean and clear bass extention , then you can set the crossover lower.Mcacc tests your speaker in room response. Not what it's rated to do.
    Think about a few things before you give up on MCACC. I usually find it to work great. And I have performed it in many different rooms.
    Dan
    Dan
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2009
    mantis wrote: »
    Dan
    Great post Mantis....Im the new owner of a 816 and i too wasnt overly pleased with the MCAAC results, ive tweaked it a little hear and there, but I think im still batteling ignorance on my part of the AVR itself. One thing for sure the difference between the 816 and the 411 was night and day, it really brought my R50's to life. I guess the xover adjustment will be the next challenge.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2009
    I use it with amazing results. Afterward I tweaked even further with my SPL meter, I totally dig my setup.
  • ntculenuff
    ntculenuff Posts: 1,146
    edited May 2009
    use mine :) have used mcacc in 3 different houses with a couple different speaker setups and the difference is there. much cleaner sounding with mcacc on.
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • Knucklehead
    edited May 2009
    Also, someone please help me understand how the LFE adjustment and the xover adjustment work together on the 816 or are they completley different adjustments for the sub. (hope that makes sense)
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Conradicles
    Conradicles Posts: 6,343
    edited May 2009
    I like it. After it runs, I make adjustments to crank up the low end to give my SDA's some extra bass.
  • jinjuku
    jinjuku Posts: 1,523
    edited May 2009
    I used MCACC EQ on my 1015 and it made a positive difference. I also went in a tweaked a bit more with the center channel and fronts. But the main thing is that MCACC got me most of the way there.
    I am house hunting now so when I get new digs I will definitely add room treatments.
  • Knucklehead
    edited May 2009
    Anybody?
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Conradicles
    edited May 2009
    Anybody?
    Example:
    If you set your speakers to Small, and set your crossover to 80 HZ, the speakers will not dip below 80 HZ and the Sub will handle everything 80 and below.
    The LFE level can give a boost to the low bass.
  • Knucklehead
    edited May 2009
    thanks for the info, given my set-up would the R50's be set to small or large?
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • renowilliams
    renowilliams Posts: 920
    edited May 2009
    My reciever was the first to have MCACC and it worked flawless when I calibrated my speakers. Was a lot easier than my Yamaha was.
    +1 on what Mantis is saying.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited May 2009
    David, I would try both settings for the R50's and see how they compare. In my setup (SDA 2's) I ended up using the large setting, however, YMMV.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Conradicles
    edited May 2009
    I use large on my SDA's.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2009
    I didn't like it as much when I had it.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Knucklehead
    edited May 2009
    Thanks Mike, I didnt want to be a pest with a bunch of e-mails, the AVR sounds fantastic, a few more tweaks and I think Ill be where I need to be.;)
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • michaeljhsda2
    edited May 2009
    Cool. Glad to hear it's working out for you. Enjoy!
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Knucklehead
    edited May 2009
    DANG!!! Now youve got me thinking bout those pre-outs on this thing........will this vicisous cycle of upgrade-itis ever end?:eek:
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Pedler
    Pedler Posts: 95
    edited May 2009
    OK thanks for the reply guys. I didn't expect so many responses.
    I used MCACC but the speaker sizes came as large. my sub was set to cross over at 80 HZ then I changed it to 50hz and it sounded better.
    I put the Mic on a tripod were I sit. and I tried the AVSforum setups they recommend. It sounds flat neutral. But Dull I am not saying that MCACC didn't tame certain issues that I have but it took the signature sound away from my speakers. So now when i watch a movie it doesn't excite me.
    When I turn it off I find it has the detail back, but it isn't 100% so I am trying to pick and choose certain parts of the MCACC.
    Mantis, you said that most rooms are not setup properly. What way is the correct way to set it up? MCACC ??
    My speakers are 20 inches from the side walls, and 12 inches from the back wall and 12 foot wide room by 9 feet high.
  • Knucklehead
    edited May 2009
    Pedler, from what I gather its best to run the MCAAC then tweak the settings to your taste. Not everyone can be blessed with the perfect room or set-up for that matter. Im sure once you've messed around with it for awhile you'll get it right. Good Luck!
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Pedler
    Pedler Posts: 95
    edited May 2009
    Pedler, from what I gather its best to run the MCAAC then tweak the settings to your taste. Not everyone can be blessed with the perfect room or set-up for that matter. I'm sure once you've messed around with it for awhile you'll get it right. Good Luck!
    Yep I agree I have done this.. I just find that after it has run I am adjusting the EQ point's and in doing so, aren't you defeating the purpose of MCACC?
    Don't get me wrong, I am not saying that the MCACC doesn't work. It has corrected different sound issues I had but to do this it has to take away from something else.
    Hopefully MANTIS can explain it seeing how he has more experience with it.
  • bsoko2
    bsoko2 Posts: 1,449
    edited May 2009
    I have a Pio '94 and MCACC is about as fool proof as can be. Of course it also helps that I have the Anti Mode 8033 to handle the sub LFE bass, then I run MCACC. Love it and never have had any problems with it. For more info on MCACC, there is a MCACC thread on AVS at http://www.avsforum.com/avs-vb/showthread.php?t=1112470.
    Bill
  • superjunior
    superjunior Posts: 1,632
    edited May 2009
    no :D
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • Pedler
    Pedler Posts: 95
    edited May 2009
    Bill[/QUOTE]
    I have done this and if you follow the posts it is the consensus that after the MCACC has been run you have to change eg. the speakers to small and re-run it again keeping the speaker sizes.
    Maybe I am just nit-picking... It's not like I would sell my receiver:eek:
    I guess I am just trying to understand why they would have you do this.
  • Pedler
    Pedler Posts: 95
    edited May 2009
    :D I have the stereo speakers sounding great now. I just have to tweak the surrounds some more.
    I am going to try and figure out the graph/DL the results to the computer.
    I think today is going to be tweaking day.
    Wish me Luck!!!!:D:D:D
  • Pedler
    Pedler Posts: 95
    edited May 2009
    xcapri79 wrote: »
    I just ran MCACC with the SC-07 and 2xLSi25's/2xC's/4x15's/4xPSW1000s with a DSW600 off the LFE.
    (The PSW1000's are connected to each of the front LSi25's and side LSi15's)
    It set everything to large which sounds right to me.
    The only changes I made was to set the DSW600 sub to plus.
    The MCACC recommended I lower its volume, which I changed to 25 from a max of 40.
    It produced some nice before and after graphs.
    I'll download them sometime when I remember to bring my laptop home.
    The difference with the Moody Blues I was playing was huge.
    In another thread, I described it as audio heaven.
    Everything sounded so right for me.
    How big is your room??? :eek::eek::D:D 4 subs you are a lucky. I don't have the space. but i could do 2 subs.
  • Knucklehead
    edited May 2009
    he either likes rap...or has a life size AMC theater in his house.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
