Vandersteen speakers.
pearsall001
pearsall001 Posts: 5,294
edited June 2009 in Speakers
Anyone ever had there ears on a pair of Richard's speakers...in particular the 2Ce SIG II & the 3A SIGNATURE? He has an interesting design philosophy that is a departure from the main stream designs for sure. They all seem to get stellar reviews. Any opinions?
Post edited by pearsall001 on
  • artinaz
    artinaz Posts: 185
    edited May 2009
    I have had the Vandersteens in the past- 1b, 2ci, 2ce, 2wq. They sound good- however really critical of room placement. In my room with high ceilings- they really did'nt gel at all- I had much better results with the polk vintage models.
    If you research these on the web, you will read only good things- so I guess it just depends on your room.
    BTW, if you have any questions and call up Vandersteen support, Richard V himself does answer the phone sometimes.
    Azi
  • thuffman03
    thuffman03 Posts: 1,325
    edited May 2009
    Never heard a set. Went out to their site and they look pretty cool. No dealers near I live either.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • mshan242700
    mshan242700 Posts: 823
    edited May 2009
    http://audioconnect.com/
    Probably not too bad a drive for OP.
    Heard their Vandersteen set-ups at shows with Ayre electronics and sound very nice (really like Vandersteen 5, but they are very expensive). Used to own Vandersteen 2ce and they are very nice for music lover (at first, may see too laid back and kind of dark, but very musical product).
    Audio Connect people at show were friendly, so if you go at a non prime time for them, I'm guessing they would be happy to audition them for you (I'd listen to them with Ayre electronics, if you can).
    edit: looks like they no longer carry Ayre. They have Magneplanar 1.6 speakers, though.
  • pearsall001
    edited May 2009
    Thanks for the info, not too bad of a drive. I'll have to check on other possible dealers also.
  • mantis
    mantis Posts: 17,394
    edited May 2009
    You know we carry them right? You r welcome to come and listen. Very impressive if you can get over how they look, I don't like the look but they are truly a fantastic sounding speaker. From top of the line to the bottom, very nice.
    I'm sure we can give you a good deal on them as well.
    Dan
    Dan
  • pearsall001
    edited May 2009
    Hey Dan, no I didn't realize that you carried them. I'll have to get up there to give them & the Mythos a listen. That should be a fun comparison. I'll be in touch.
  • GreggC
    GreggC Posts: 23
    edited May 2009
    I listened to the 2Ce's a while ago and really liked the sound - always wanted to get a pair.
  • muncybob
    muncybob Posts: 3,240
    edited June 2009
    I own a pair of 2CE. The room is less than ideal and they are probably placed too close to the room corners. I enjoy their sound...I find their mids and highs to be very clear and "crisp" but not over emphasized. I run them with a 12" subwoofer and all is great! I wonder how much better they would be in proper placement.
    Yep, my name really is Bob.
  • mantis
    edited June 2009
    A bit of unfair as the Mythos St destroy the Vandersteins but thats in my opinion. Some may like them more. The St's go deep and strong and the top end is tight and controlled. It's a full range speakers. The V's don't dig like that and they need a lot of power to drive them. Wonder speakers when setup properly. I did a guys system with a full 7.1 and B&K and it was a very Impressive sounding system. I liked it but hated that way they look.
    Send me a email or call me. We can hook up at the Lab and do some demoing. It will be fun. I will bring the St's in the V room and do a side by side. Or we can go into the High end Krell room and get nutty.
    Dan
    Dan
  • ohskigod
    ohskigod Posts: 6,505
    edited June 2009
    I consider the 2C's one of those "must own on the road of audiophiledom" speakers. I sold mine, but still have a soft spot for them. One of those "had to sell to continue on the journey" speakers that you can REALLY miss
    they gobbled the power from my Carver and sounded damn good doing it. one word description? SMOOTH!
    Definitely one of those speakers that if they come off "bright", you have either dire issues in your chain, or listening environment......or probably both
    Russman said I was nuts for selling them, the man with the huge mellon and tiny neck had a point.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
