home theater center channel down for the count
danger boy
danger boy Posts: 15,722
edited May 2009 in Electronics
Tonight.. while watching a movie.. the center channel started to go in and out. It has been happening for about two weeks now.. on and off.. finally I noticed tonight that there was no sound coming from the center speaker.
Thought maybe just a loose wire.. nope. The center channel has a hum in it.
here is how it's wired..
blu ray player to pre amp via 5.1 analog cables for audio.. video is via HDMI to new LCD tv (looks amazing)
pre amp hooked up to amps.. three front mono block amps.. rear is a two channel stereo amp. all work fine except center has a hum and no sound.
so the problem could be the RCA cable from the center mono block to the pre amp..
OR
the center channel pre amp output may be bad
OR
the mono block that runs the center channel is dead.
OR
the cable that runs from the mono block to the pre amp could be bad..
OR
the center channel cable from the blu ray player to the pre map may be bad.
UGH.. so much to check and try and isolate the problem.
so this weekend. I am tearing everything down and doing a total rewire of all the audio and video cables in the home theater.
any ideas on the easiest way to accomplish this?
*listening to movies in 2 ch leaves a lot to be desired.. at least in my set up it does. :( at least the subwoofer still works ;)
PolkFest 2012, who's going>?
Post edited by danger boy on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited May 2009
    Hire somebody to do it for you? No, j/k sounds like it is going to be a pain in the butt hope you get it fixed up.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • danger boy
    edited May 2009
    i just swapped out the RCA cable from the pre to the amp.. the hum got worse.. to the point of really loud crackling.. i freaked how loud the pop and crackeling was. I quickly turned everything off.
    Must be a short somewhere.. I will check all cables.. but yeah. that would be the easiest thing to do..
    but.. i haven't rewired the HT in years.. and it's a big rats nest behind the wrack.. so it needs to be cleaned up.. and rewired.
  • wutadumsn23
    edited May 2009
    Good luck neighbor, if you need any help I'll bring the beer and pizza, lol.
    HT Rig
    Blu-Ray- 80 GB PS3
  • mantis
    mantis Posts: 17,424
    edited May 2009
    danger boy wrote: »
    Shame I don't live closer, I could come over and knock that out for yeah. Wire management is one of my strong points. Hopefully you just have a bad IC, or just a dirty connection.
    Dan
    Dan
  • dpowell
    dpowell Posts: 3,081
    edited May 2009
    It's amazing how much faster it is to tear down a system than it is to get everything plugged back in just the way you want it. :/ Good luck with the rebuild. Hope you find out what is wrong on the first couple of troubleshooting steps vs it being the very last thing you try. :)
  • wutadumsn23
    edited May 2009
    How did it turn out??
    HT Rig
    Blu-Ray- 80 GB PS3
