Lsi 7 & 9
renowilliams
Just wonder if I were to purchase one of these models, given their power requirements, whether my avr would drive them ok in 2 channel.
"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
Post edited by renowilliams on
From reading what others were saying about their 4ohm speakers and this receiver, it should be fine to use with the LSi series.SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
renowilliams wrote: »Just wonder if I were to purchase one of these models, given their power requirements, whether my avr would drive them ok in 2 channel.
Your AVR is quite the beast at $4500 list price.
http://www.pioneerelectronics.com/PUSA/Products/HomeEntertainment/AV-Receivers/EliteReceivers/VSX-49TXi?tab=B
You should be fine. I ran 4 LSi15s and an LSiC off a $1000 Sony and Denon AVR with no issues in full HT mode. Two channel should be no problem. Personally, while the LSi7s are nice little speakers (I have two), I would get the 9s, or even the 15s instead.
I must add the obligatory Polk Forum disclaimer here: You need an external amp with the LSi series. Blah, blah, blah.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Good work on the blah..blah...blah...you are right.
Hey Tim....what does that Pioneer say on its speaker terminals? 6-8 ohms or is there a 4 ohm setting?
CNH is right you need to check out what Pioneer says about running 4ohm speakers.
Not that you couldnt hook them up and you would hear sound, but you would probably mess the speakers up.Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's -
This is what Ultimate AV mag said when it did a review and took measurments;
With six channels driven into 8ohms (our test bench load is limited to six channels), the VSX-49TX clipped (1% THD+noise) at 123W at 20Hz and 129W at 1kHz. With six channels driven into 4ohms, clipping occurred at 187W at 20Hz and at 201W at 1kHz. The receiver shut down on the latter test from a blown internal fuse, but functioned normally again when the fuse was replaced. This test is extremely challenging; such a failure would be very unlikely in normal operation, even high-level playback of the most explosive music or soundtrack. With five channels driven into 4ohms, the Pioneer clipped at 196W per channel at 20Hz and 209Wpc at 1kHz, left channel measured, without shutting down. The output with five channels driven into 8ohms was 133W at 20Hz and 137W at 1kHz. With two channels driven at 1kHz, clipping occurred at 168Wpc into 8ohms and at 241Wpc into 4ohms, left channel measured, at 1kHz.—Thomas J. Norton
Not quite sure what it means though.
OK, just read the manual and it says nominal impedance of 6-16 ohms. Guess not.
Oh well, Guess I'll have to get a power amp. I wanted an excuse anyway...lol"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
renowilliams wrote: »This is what Ultimate AV mag said when it did a review and took measurments;
With six channels driven into 8ohms (our test bench load is limited to six channels), the VSX-49TX clipped (1% THD+noise) at 123W at 20Hz and 129W at 1kHz. With six channels driven into 4ohms, clipping occurred at 187W at 20Hz and at 201W at 1kHz. The receiver shut down on the latter test from a blown internal fuse, but functioned normally again when the fuse was replaced. This test is extremely challenging; such a failure would be very unlikely in normal operation, even high-level playback of the most explosive music or soundtrack. With five channels driven into 4ohms, the Pioneer clipped at 196W per channel at 20Hz and 209Wpc at 1kHz, left channel measured, without shutting down. The output with five channels driven into 8ohms was 133W at 20Hz and 137W at 1kHz. With two channels driven at 1kHz, clipping occurred at 168Wpc into 8ohms and at 241Wpc into 4ohms, left channel measured, at 1kHz.Thomas J. Norton
Simple, can not set the LSI to hear sing.
Amplifier 300 watts at 4 ohms is basic.
1) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
2) HITACHI P55T501. 55" HD1080 Plasma HDTV
3) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
4) DENON DVD-2500BTCI: Blu-ray Disc DVD/CD Digital Player/Transport (
5) POLKAUDIO LSiC (Center speaker)
6) POLKAUDIO LSi15 LEFT (Front speaker)
7) POLKAUDIO LSi15 RIGHT (Front speaker)
8) POLKAUDIO LSif/x LEFT (Surround speaker)
9) POLKAUDIO LSif/x RIGHT (Surround speaker)
10) SONY SA-WP16 ( Sub Woofer 2X200W) -
You might be able to run small LSIs with that but don't push them too far. That's my reading on those specs. Do you have a manual? And does the manual say anything about a 4 ohm setting for speakers. Because although, in most cases, like the Onkyos, such settings are limiters that reduce actual wattage. They save you from blowing fuses or speakers...and that Pioneer has pre-outs so you can always get external amps later...and just run them with the Pioneer. I can't imagine that the Pioneer would NOT be able to run them at decent volumes--that was the flagship that year!
renowilliams wrote: »This is what Ultimate AV mag said ...
Check your facts very carefully. Some receivers are actually well known to be fully rated for 4 ohm use, and lower, without any power limiting switches or other nonsense (albeit, not very many). Of those, I have never heard a single report of failure or protection modes being engaged with difficult loads, so you will not be risking damage to your speakers or voiding your warranty, but they may not have all the processing abilities that first attracted you to the Pioneer.
After that, you'll have to decide if you want to be Cathy approved for flight, or not, and others will join her to argue that you will never get the best out of your LSi speakers without 200w/ch of external amplification. Only you can decide what your priorities are, but at least be aware of the possible consequences.
P.S. The price of a receiver has nothing to do with whether or not it can drive a 4 ohm load.Alea jacta est! -
Well there is no sence taking chances. I will buy a power amp before I get 2 channel speakers. Thanks for the info everyone.
Much appriciated.
Tim"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
Actually for a multi ch reciever it appears to do a credible job driving 4 ohm loads.It certainly didn't fall flat on it's face according to Ultimate AV's test.Testing
Testing
Testing -
You might be able to run small LSIs with that but don't push them too far."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Actually, the LSi9 is a more difficult load than the LSi15. The 9 dips down to 2ohms, meanwhile the 15 only dips down to 3ohms. I haven't tested a LSi7 or 25 yet, but I would assume that they're the easiest to drive.
Is that true?
As verify the information?
Has the file or web address.
The LSi9 impedance curve is easy to find via google. I tested a LSi15 with a WT3(woofer tester 3)."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Verified by the NRC.
http://www.soundstagemagazine.com/measurements/polkaudio_lsi9/Testing
Testing
Testing -
Looks like the average impedance is around 5-6 ohms.Lumin X1 file player, Westminster Labs interconnect cable
The problem area is in the 200hz range and below where both woofers are operating in parallel and the dip to 2 ish ohms at 50hz which appears to be the ports tuning frequency.
There is usually a lot of musical content in this range, so combined with the lowish impedance will make it quite demanding of the amp driving it.Testing
Testing
Testing -
http://www.soundstagemagazine.com/measurements/polkaudio_lsi9/Looks like the average impedance is around 5-6 ohms.
The information is very old. Is the same for new versions of the LSI.
Have results for LSi15? -
Those specs should be the same as current. As I mention above, according to my measurements LSi15's only briefly dip down to 3 ohms, so any 4 ohm capable amp shouldn't have a problem driving them."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Your AVR will work,but an Amp will be much better.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
you paid 4500 for avr?I am 100% BORN DEAF and No I am not kidding! Why am I here? My wife's hearing!
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA -
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
The link to the LSi9 impedance measurement appears to have disappeared. Are the actual curves posted somewhere else in this Forum?Testing
Testing
Testing -
Here you go....Mains.............Polk LSi15 (Cherry)
Agree with what Cathy always suggests - I have the said speakers (LSi9) that I did initially drive through a Rotel RB-991 2 channel amp - 200 watts into 8 ohm / 300 into 4 ohm. I sold the said amp and was running my LSI-9s through my Denon 3808 only. Although it did sound acceptable still, the full capability of the speaker was no longer there - a noticeable difference. I again now have a Emo MPS-2 200 watt into 8 ohm x 7 / 300 watt into 4 ohm x 7 and the full potential of the speakers have been restored.
There is a good old saying, you never know what you have got until it is gone.......Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
