Micropro 1000 Sub responds to any remote
edited May 2009 in Troubleshooting
I contacted Polk Support with a problem about my Micropro 1000 responding to My Musical Fidelity A1 volume control, they said it was possible the two remotes shared code sets. However, tonight I had the same problem when I was changing tracks on my Marantz SA-8001 and the Micropro responded and changed volume. I quickly grabbed another remote to my Denon 3901 and hit play, and the sub changed volume again. It's like it intermittently will go into a mode for a few seconds where it will respond to ANY IR code. Anyone ever see this issue before?
Post edited by Polkitup2 on
Welcome!
    edited May 2009
    I have this sub and never noticed the issue before. The sub is usually out of the IR range when I'm using my remote for other things.
    I'll try to give it a shot tonight to see if it affects me as well.
    edited May 2009
    It happened to my Micropro 3000 with my previous preamp's remote. It didn't happen always, just randomly.
    SOPA
    edited May 2009
    Interesting issue. I never had a sub with an IR port. I always had to walk over to the sub to adjust the volume if needed.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
    edited May 2009
    Ricardo wrote: »
    Yep, it's only random, I can never re-create the issue when I want. But when it goes into that mode, it seems to respond to any code from any remote for a few seconds.
    edited May 2009
    I had the same problem with my Micropro 3000. My solution I just turned it sideways so the Ir was out of sight. It may not look as nice turned sideways but it still sounds great.
    edited May 2009
    Nicknice wrote: »
    Looks like a good solution, or simply tape something (like a piece of electrical tape) over the IR receiver window on the sub. You don't need to adjust the level of the sub anyway, after it's calibrated into the system.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
Welcome!
Welcome!
