how many watts of..
CaligulaPolk
CaligulaPolk Posts: 1,650
edited May 2009 in Speakers
amp juice are powering each of your speakers ? i am researching amp power watts and like to know what or how much watts juice you guys have . also at what ohms too. please share your info for my research... 5.1 or 7.1 LSi or RTIA Series is what im looking at but your speakers arent necessarily have to be LSi or RTIA
was thinking emotiva xpa 3 for front and upa2 or xpa 2 for rear to power lsi 15 or 25, RTIA 9 and rti a3 power by onkyo 805 avr
what do ya guys think?
I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
Post edited by CaligulaPolk on
    edited May 2009
    It makes a difference. I'm only running M70s and I can hear it off a Denon AVR 2807....110W/7channels. I have an Adcoms-GFA 555....200 watts into 8 ohms/channel, 325 watts into 4 ohms. Makes those M70s SING! You can really hear a significant difference. I'd recommend adding the amps. Emos are used by a lot of guys here--they should be OK.
    cnh
  • Mike21
    Mike21 Posts: 252
    edited May 2009
    Hi CP.
    My rule of thumb is for amp power is based on the speaker manufacturer's recommended range of wattage. For example, if the mfcr recommends 25w to 150w I would use between the mid point of the range (about 90w) and 30% over the max (200w in this case). The more power the better the speakers will respond (and sound).
    Mike
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • CaligulaPolk
    edited May 2009
    cnh wrote: »
    cnh
    i chose emotiva bec its cheap and will put juice on bass since i cant hear sound but wife can.. dont see why i should buy expensive amp.
    and will onkyo be ok powering lsi 9 if i go for 7.1? how much of juice will lsi9 or rtia3 get from onkyo 805 while other are hooked to amps ?
  • VXR8
    VXR8 Posts: 291
    edited May 2009
    If you go with XPA-2 and XPA-3, you should use the 2 for the fronts and the 3 for centre and surrounds - 2 will input 500 watts into 4 ohm and is designed more for 2 channel listening as well.
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • CaligulaPolk
    edited May 2009
    VXR8 wrote: »
    500 watt each or both fronts? good suggestion would lsi be ok with 500 w each??
    heiney9 Posts: 25,221
    edited May 2009
    30 wpc to my SDA 1C's.....better than my previous 125wpc amp in every way.
    Emo seems to be the flavor of the month. Some like them some hate them. Myself from what I;ve heard so far for 2 channel music.............I will steer clear of them. Probably a decent value for the $$$ buying new. You have better choices going used.
    YMMV
    edited May 2009
    That's a good question...do you mean you're only going to power 2 LSI-9s with the Onkyo and the other 5 channels with Emotivas? That might be OK if the LSI-9s are just surrounds? It would help to have someone with that config jump in here!
    cnh
  • CaligulaPolk
    edited May 2009
    cnh wrote: »
    cnh
    correct how many watts will onkyo juice lsi 9 if i decide go for 7.1 i plan us floorstander speakers for front and rear with amp.
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2009
    Caligula, you have been here long enough to know the answers to these questions. They come up at least once a week.
    If you have LSI's give them at least 200wpc @ 8ohms If you can afford more buy more.
    Get a Emo XPA 5 & be done with it. And if you decide to go with 7.1 with the LSI 9's then get a 2 channel XPA to run those.
    Or get an Outlaw 7700 7 channel amp.
    Shop Audiogon for a used one as well.
    treitz3 Posts: 19,276
    edited May 2009
    Watts are over rated.
  • VXR8
    VXR8 Posts: 291
    edited May 2009
    Sorry - yes 500 watts per channel into 4 ohm load - LSi will be fine with that - think of it like a V8 engine, power on tap when required but you never usually max it out.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • CaligulaPolk
    edited May 2009
    cfrizz wrote: »
    yea thats true but am looking emotiva stuff now since i made decision to get amps first before i buy speakers iwhen i move to florida and probably wont have internet access anytime soon plan buy amp after july 4th.
  • CaligulaPolk
    edited May 2009
    would 125 watt per channel,upa7 make rti a9 bass more punchy ? or the more watts than 125 , more better punchy bass from speakers ? i suspect it would make lot difference if i go for more watts
  • McLoki
    McLoki Posts: 5,231
    edited May 2009
    Cinepro 3k6 - 500wpc (@4ohms) to my passive SVS subwoofer and 5 channels of my LSi home theater. (LSi15, 7, C)
    Adcom 7500 - 150wpc (@ 8ohms) to my monitor 10's.
    Onkyo 777 - (probably about 100wpc to 2 channels worth of RTi6's)
    Michael
  • CaligulaPolk
    edited May 2009
    McLoki wrote: »
    Michael
    you can hook subwoofer to amp? does it make subwoofer more punchy bass ?
  • polkie4life
    polkie4life Posts: 231
    edited May 2009
    SRT
    sda array 400w @ 8ohms
    stereo array 400w @ 8ohms
    Subs 400w @ 8ohms
    RT55i wired in parallel for centers 170w @ 8ohms
    FX500i 170w @ 8 ohms
    In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
    http://www.polkaudio.com/forums/showcase/view.php?userid=86838
  • polkie4life
    edited May 2009
    McLoki wrote: »
    Michael
    It's an awesome thing running a passive sub off the cinepro aint it?
  • McLoki
    McLoki Posts: 5,231
    edited May 2009
    To a passive subwoofer - yes. It does not have an external amp - just a pair of speaker terminals (and no crossover).
    I have one passive and one active sub. (both SVS 25-31 plus subwoofers - one a CS + (passive) and one a PC + (active).
    Michael
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited May 2009
    I have a Yammha AVR at 100 wpc driving the HT. For the fronts, which also serves as my 2 channel system, the fronts were too muddy when working the rig in 2 channel mode. The bass was way too mushy. The preouts were then bridged into an ancient 2 channel yammy amp guaranteed at 130 wpc w/350 wpc dynamic headroom at 4 ohm (over 500 at 2 ohms). That circa 1990 beast has caps the size of large salt & pepper shakers that would probably electrocute you if you touched their terminals with the caps being in an engergized state.
    What a difference! Everything is nice and tight with organ jiggling lows being generated while still having the other speakers on hand for HT mode. Buy as many watts as you care to afford.
    Just make sure the amp is capable of dynamically delivering the wattage needed when demanded. That is the key. Based from your other posts in this forum, you already know not to overdrive the amp into the speakers, so no advice will be offered there. ;)
  • Face
    Face Posts: 14,340
    edited May 2009
    20wpc in triode is just enough for me.
  • Hilbert
    Hilbert Posts: 316
    edited May 2009
    xpa-5 driving LSi9s, 7s, and C. Rated (as surely everyone knows since after all it's Emotiva) 350 wpc @ 4 ohms.
    For a while I had just the two 9s, 450 wpc, sounded great. Sounds great now (I think :)).
    My advice, echoing previous advisors, is get the xpa 5 now and try running the way in back speakers off the avr, or just run 5.1. If that's not satisfactory maybe down the road get the -2 for the fronts and use the -5 for the rest.
    edited May 2009
    I don't mean to disagree but 2 surround back channels. It's not like there's a lot of information on those tracks. Power amps? I think it could work either way. That receiver should be able to power a mere two channels of fairly weak 2 channel back sound. But to each his/her own. Got to go with Hilbert above on this.
    cnh
    mhardy6647 Posts: 34,054
    edited May 2009
    Roughly 14 watts per channel (push-pull EL84). The main rotation of speakers in the living room: Altec Valencias, DIY mass loaded tapered quarter-wave tubes loaded with Radio Shack 5-1/4" twincone fullrange drivers, and Quad ESL-57s.
  • CaligulaPolk
    edited May 2009
    cnh wrote: »
    cnh
    was looking emotiva website. ill buy xpa5
    but should i buy xpa5 first or buy speakers first?? what do u guys suggest?
    edited May 2009
    What are you using for speakers now?
    cnh
  • Hilbert
    Hilbert Posts: 316
    edited May 2009
    FWIW, I'd pick the speakers first, then find an amp that will drive them.
    OTOH, xpa-5 should be able to drive almost anything, and is said (by Emotiva) to be neutral-sounding, so perhaps in this case order doesn't matter.
    The amp weighs about 75 lbs, about 90 in the box, so schlepping it from PA to FL might be an unpleasant chore.
  • Hillbilly61
    edited May 2009
    Hilbert wrote: »
    That's the optimal way to buy gear. Unfortunately, reality raises its ugly head when you are just upgrading components. New speakers, amp doesn't mesh anymore, etc.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2009
    I use a dedicated amp for my RTiA3 fronts and the avr amp for the center and surrounds.
    modified Carver M-1.0t mkII:
    Power
    8 ohms--400 watts <0.15% THD
    4 ohms--450 watts <0.15% THD
    At Clipping
    8 ohms--450 watts
    4 ohms--500 watts
    Dynamic
    8 ohms--670 watts
    4 ohms--832 watts
    I never need worry about headroom...:D
  • markmarc
    markmarc Posts: 2,309
    edited May 2009
    Be careful about falling into the wpc trap. It's all about quality power, not quantity. My 38wpc int. tube amp offers far more quality power and can drive difficult speakers better than many of the big names mentioned here.
    Right now I have a well-known quality Canadian company's 40wpc int. amp in for review, next to it is a 150wpc class d amp. The 40wpc is pummeling the 150wpc with a fairly difficult set of speakers. The sound has more weight, dynamics and thrust during difficult passages.
    Former Staff Member TONEAudio
    2 Ch. System
    edited May 2009
    marcmarc,
    That's not fair...most of us know that tubes put out more quality watts than cheap SS units. I think that appropriate thing to say is if you're not running a tube amp or a good class A, then a 200 Watt/channel by a reputable manufacturer, i.e., Carver, Parasound, Adcom, Rotel, Cambridge Audio, Bryston, etc. Will give you good sound. You need to listen to a range of amps to see what you like in sound...and remember that your pre-amp will ultimately affect what kind of sound you hear also.
    cnh
