Can I increase subwoofer input signal?
Polkitup2
I am having trouble driving my Polk DSW Micropro 1000 due to a low pre-out signal from my Musical Fidelity A1 integrated. I'm using the L/R line inputs on the sub. Essentially, even with the sub at full power my SPL levels are only 65 - 70 db. So I am wondering how I could increase the pre-out signal strength? Can I use a pre-amp line driver such as this?
http://www.kollmanradio.com/product_info.php?products_id=5603
Any other options for getting a better signal to my sub?
Post edited by Polkitup2 on
I had this issue once and these are the things that worked for me. My receiver had only 1 RCA preout for my sub and my sub had 2 RCA input jacks. I bought an RCA Y adapter and ran my sub cable from my receiver into this and then the Y adapter into the sub. When connecting both to the sub you get about a +3db boost to the signal (I read this somewhere when I was looking for a solution). I also tried boosting the gain for the sub in the settings menu. You may want to try another sub cable as well to see if that helps. Good luck. -
Thanks for the suggestions, I am almost coming to the conclusion that the music I listen to doesn't have much deep bass so there is only so much a sub can do for me. I did get a little more volume from increasing the crossover setting.
