psw 140 fuse keeps blowing out
laxhead94
hi,
i recently came into possession of a polk audio psw 140 powered subwoofer and after about a week of use the fuse blew. i went to radioshack and picked up similar fuses ot the one in the sub. as soon as i put the new fuse in and plugged it in the fuse blew.i tried this three times on different phases and the same thing happened. can someone help me with this problem??
Post edited by laxhead94 on
If the fuse is blowing, you've got a short, and it's probably in the plate amp. You can take the sub in for servicing, or call polk customer service and ask how much a plate amp is if the sub isn't under warranty any more. You'd also get a discount for being a member of the forum.
Welcome to the forum. Sorry it's under such circumstances.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
ok but which one is the plate amp??
