How to get a lsi9 woofer out ...
wizzy
wizzy Posts: 867
edited May 2009 in Troubleshooting
Argh.
Removed all the screws from upper woofer but can't figure out how to get the thing to pop out.
Post edited by wizzy on
  • wizzy
    wizzy Posts: 867
    edited May 2009
    Figured it out.
    I cut the cone out of the speaker. Still couldn't get it out. Then I got a claw hammer, clawed onto the speaker basket, and pulled like a **** finally ripping it from the cabinet.
    That seems a little excessive as far as speaker design, no??
    Using the laquer whatever finish to double as glue to glue the driver on?
    VR3 Posts: 28,815
    edited May 2009
    Yeah, some manufactures go nuts. I opened up a VMPS Tower II one time - broke 2 knives in the process. He used double sided tape to seal them.
    Talk about excess!
  • Face
    Face Posts: 14,340
    edited May 2009
    You could have removed the tweeter or other woofer and pushed it out from behind.
    It appears the paint isn't fully cured when the woofers are installed, sometimes making it difficult to remove them.
  • wizzy
    wizzy Posts: 867
    edited May 2009
    Tried that. Same luck getting bottom woofer out so I just put screws back in, and tweeter would not come out more than about 1/8" before I felt it resisting ...
    It seriously took a lot of yank to get it out.
  • Face
    Face Posts: 14,340
    edited May 2009
    If the tweeter moved at all, it was the cables from the x-over holding it back. A little tugging would have given you the slack you needed to remove it.
  • Face
    Face Posts: 14,340
    edited May 2009
    As for the bottom woofer in LSi9's or right woofer in a LSiC, remove the binding post cup and you can push from behind.
  • wizzy
    wizzy Posts: 867
    edited May 2009
    Face wrote: »
    oooh, that's handy to know ... thank you!
  • Rocco1
    Rocco1 Posts: 190
    edited May 2009
    OP why are you removing the speaker?
    Man Cave: 7.1
    -PS Audio Power Plant Premier
    -PS Audio Power backup
    -Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
    > Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
    >Sub = MK Audio 10'
    -PS3
    -Onkyo 5 disc cd player
    -Directv
    -Samsung 59' plasma flanked by 2 Samsung 43' plasma's
  • wizzy
    wizzy Posts: 867
    edited May 2009
    Rocco1 wrote: »
    Had to install a replacement ... thus I didn't mind ripping the cone off to get it out.
