sl2500?
seeclear
seeclear Posts: 1,243
edited May 2009 in Troubleshooting
I am looking at a pair of RTA 8TL's from my local CL, and the seller says a tweeter is bad. After calling Polk CS (Eric (Wong?)) and asking for a replacement sl2500, he said it was available, but after reading more on here, it seems like that may not be the original sl2500 but the RDO198? So, the ? is, is the sl2500 original still available from Polk directly, or is it the RDO198? If it is the sl2500 I think I would just replace the one, but if it is the RDO198 I would most likely replace both channels, so it does make a little bit of difference how much I want to spend on these.
Thanks in advance for your help.
"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
