Dynamat
Stevenmbell
Stevenmbell Posts: 60
edited May 2009 in DIY, Mods & Tweaks
I put dynamat inside my cd player what a difference in sound. I love it any one else ever tried Dynamat?
2 CHANNEL:cool:
Belkin PF31Pure power/AV Conditioner
NAD C165BEE PreAmp Great Phono Section
B&K ST1400 S2 Power Amp
Audio Quest 4 Speaker Cables
ProJect RPM 1 Carbon
Ortofon Blue Cartridge
Quadio Interconnects
Denon 2910 DVD-A/SACD Player
Pangea SE 14 & AC9 Power Cords
Vifa DIY 3 ways Sound is incredible. :biggrin:
Post edited by Stevenmbell on
«13
  • skrol
    skrol Posts: 3,480
    edited May 2009
    I have seen this done before to CD, tape decks and turn tables. I am considering doing mine.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2009
    forgive my ignorance but please explain how this is accomplished.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Stevenmbell
    edited May 2009
    You take the cover off check to make sure you can put the dynamat inside it without contacting anything
    2 CHANNEL:cool:
  • Stevenmbell
    edited May 2009
    I put it on the transport and the trans port is so quite. The difference is amazing
    2 CHANNEL:cool:
  • Knucklehead
    edited May 2009
    ok i see.... but how does that improve the sound of the player itself?
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Stevenmbell
    edited May 2009
    The transport is much more stable. The resonence is nill
    2 CHANNEL:cool:
  • Stevenmbell
    edited May 2009
    Have you heard of jitter well I take it that the jitter is stopped by the deadning effects of the Dyna
    2 CHANNEL:cool:
  • Knucklehead
    edited May 2009
    very interesting. thanks for the tip.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Stevenmbell
    edited May 2009
    All I know is the level of sound and detail is increased like you won't beleive
    2 CHANNEL:cool:
  • Stevenmbell
    edited May 2009
    welcome
    2 CHANNEL:cool:
  • Stevenmbell
    edited May 2009
    Also put it on the cover every where you can
    2 CHANNEL:cool:
  • nikolas812
    nikolas812 Posts: 2,915
    edited May 2009
    I experienced the exact same changes in sound when I covered the inside of my Jolida CDP with dynamat.
    A very nice and cheap tweak if you ask me. Fun and easy to do..
    Nick
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited May 2009
    I have used Dynamat Extreme on my Arcam CD72 CDP my Anthem PRE2L tube pre-amp and all baskets on my drivers and passives in my SRSII's and SDA2a's. An excellent low cost tweak/upgrade.
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    Id like to put some of this stuff in my CDP and DAC.Should I go with regular or extreme?And is this a good deal>> http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=160329383125
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • quadzilla
    quadzilla Posts: 1,543
    edited May 2009
    Got any pics of that?
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Knucklehead
    edited May 2009
    what concerns me is the potential for heat build up.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Stevenmbell
    edited May 2009
    I'll take some pics tuesday night and post them wednesday.
    2 CHANNEL:cool:
  • Stevenmbell
    edited May 2009
    no heat build up unless you cover any holes. Just cut out around any holes.
    2 CHANNEL:cool:
  • Stevenmbell
    edited May 2009
    extreme is very thick , Ithink you'll run into problems with the thicker matieral. but you may not. I know in my case I would have been hitting against the transport if I had used thicker stuff.
    2 CHANNEL:cool:
    F1nut Posts: 52,159
    edited May 2009
    Dynamat will not and cannot remove jitter. Jitter is a time based issue and has nothing to do with vibration. If one wants to address jitter issues, you have to upgrade the clock.
    Vibration issues is what applying Dynamat helps to control. Do not use regular Dynamat, only Dynamat Extreme.
  • Knucklehead
    edited May 2009
    Is it possible to have vibration problems within a dvd player for example?
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    F1nut Posts: 52,159
    edited May 2009
    Of course. Vibration can be an issue with just about any piece of audio gear.
  • Knucklehead
    edited May 2009
    Thanks I just didnt want to try something that might not work for a certain peice of equipment. I have an older dvd player that is out of warranty I think ill give it a try on. Now that I think about it I guess the disc spinning could create vibration.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    F1nut Posts: 52,159
    edited May 2009
    What one is trying to do is keep vibration created by the music/movie playing out of the piece. It's basically the same principle as using isolation points/feet under a piece of gear only instead of trying to prevent vibration from transferring from the rack/table/stand to the piece, you are trying to keep vibrations in the air from transferring into the piece.
  • Knucklehead
    edited May 2009
    Gotcha, thanks for clearing up what i was trying to put on paper:D
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2009
    Would you say it is more effective to do so internally then externally by means of rubber feet?
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    F1nut Posts: 52,159
    edited May 2009
    Well, each serves a different purpose, but I guess I'd have to go with the internal over the external as most of the better gear come with decent footers to begin with.
  • nikolas812
    edited May 2009
    Why?
    Nick
  • CoolJazz
    CoolJazz Posts: 572
    edited May 2009
    nikolas812 wrote: »
    Why?
    Nick
    Because Jesse is extreme!! :cool:
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    F1nut Posts: 52,159
    edited May 2009
    LOL......I'm too old to be extreme any longer.
    The Extreme is an improved version. It has excellent adhesion properties and has a layer of aluminum on the face side making it easier to work with. It also provides better protection from heat.
