12au7 tubes
VR3
I need suggestions -- NO 12ax7, just 12au7
I am currently just running standards JJs --- they are ok.
I have on order a pair of RCA clear tops...
Others I have read about are the RCA blackplates
And some others that I forget...
Any other suggestions...
I want resolution and midrange bloom with tight bass and wide staging... to give some suggestions...
See associated equipment below. I am running the SS output on the Shanling right now.
Post edited by VR3 on
Talk to this guy
http://trade.audioasylum.com/ca/listing/Tubes/Westinghouse/12AU7A/Vacuum-Tube-Valve-Fest/15801JC approves....he told me so. (F-1 nut) -
I've been using the RCA clear tops in my Ming Da and they are fantastic. I think you'll like them. I've always gone back to them. I think you'll definitely get the mid-range bloom and decent soundstaging. My bass has never been accentuated, if that's what you are after, but I guess I'd call it tight. I don't really like the bass to get in the way anyway. I'm not sure how easy it is to get everything out of one tube either, but the clear tops are definitely detailed with a gorgeous mid-range.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Sylvania Triple Mica Blackplates.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Find some Siemens 5814A and be done with it. Probably the best 12AU7 type tube out there. Though, it's always nice to have Mullards when you feel like swimming in a pool of chocolate.
My favorite by far is the Amperex Holland D-getter ECC186 7316 PQ. it is a super premium varient of the 12AU7 that was designed for use in computers. i had a pair in my Candela and i use a pair in my VTL TL 2.5Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers. -
I just recently popped these into my Jolida JD9A. They are cheap and sound very very good. http://thetubestore.com/mu12ax7.html
raytheon 12au7
raytheon 5814wa
brimar 13d5
rft ecc 82Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I got my RCA cleartops - initial impressions are very positive. I do not have to turn it up near as loud to get the midrange clarity and "mass" I like. And the staging is very expansive. Nice high end extention.
Low volume staging and detail.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Cool. I liked the RCA cleartops as well. In my rig, was very lush and warm. Smoother than Mullard, which was quite surprising.
What is it that you didn't like about the JJ? In many equipments, I've tried them in, they were among the best current production tubes. -
Well, I know how this rig should sound and I know the sound I want and I've heard it in here before. So I know the Teslas were holding me back. To get the sound I wanted, I was having to run full volume - that gets old quick!
These RCAs have the sound the Teslas have at full volume - but at all volumes. Which is what I am after, not to mention far more control it seems.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey,,are you using the RCA Cleartops _______ plates(grey)?JC approves....he told me so. (F-1 nut)
Vr3MxStyler2k3 wrote: », I was having to run full volume - that gets old quick!
Sounds like you had some weak or defective JJ's. If you're experiencing that much of a difference in gain, something was up with the tube. Do give them another chance next time you come across some JJ's. -
These were brand new JJs - burned in by Alex G. So not sure. I will probally try the Longplates.
And yes George, these are gray (I believe)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I just picked up some RCA cleartop--greyplates,,and the midrange is very good,,smooth, but not too bloomy,,quite good,IMHO.JC approves....he told me so. (F-1 nut)
I am really digging the sound. It far superior to the JJ Teslas in just about everything. It has all the improvement I was looking for.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
