Passive PSW-1000?
badfireguy
badfireguy Posts: 11
edited March 2011 in DIY, Mods & Tweaks
Could anyone tell me if Polk ever made a passive PSW-1000? I don't they ever offered one. Found a guy trying to sell one as refurbished, but no amp? Any help would be appreciated!
If God had intended for us to listen to anything made by Bose, surely he would not have given us ears.
  • bsoko2
    bsoko2 Posts: 1,449
    edited May 2009
    They show up on ebay all the time.
    Bill
    heiney9 Posts: 25,724
    edited May 2009
    IIRC, the PSW1000 had some issues with the amp and they were recalled and actually discontinued. Perhaps (and this is just a guess) he is selling it sans amp because of the recall or a damaged amp. I don't think there was ever a solution to the problem and might be why the PSW1000 was eventually discontinued.
    This is all from memory so take it FWIW. Maybe some one else will chime in and clear things up.
    Give Polk CS a call they are always willing to help and are straight shooters.
    edited May 2009
    Kex wrote: »
    This was still being sold by authorized dealers, and in the Polk eBay store, earlier this year.
    http://www.polkaudio.com/homeaudio/specs/recent/psw1000/
    Perhaps the issues were rectified. I do know that shortly after the issue was discovered there was a long delay for "new" product and then the PSW1000 was discontinued.
  • megasat16
    megasat16 Posts: 3,521
    edited May 2009
    Before PSW1000, there is another type of subwoofer called LSiW which looks identical to PSW1000 in appearance. They were sold in BB and Frys; etc. in the early 2000s but later recalled due to sub plate amp problems with heat and possible fire hazards.
    Polk had dismantled all the recalled sub and destroyed the plate amps. There is a guy in San Diego area who still has LSiW enclosures with dual sub drivers selling on eBay.
    PSW1000 is the later revision of the LSiW with two very totally different parts (different driver and different plate amp) so you can't and shouldn't use PSW1000 sub plate amp in the LSiW.
    PSW1000 still carries resemblances to LSiW by appearance but the PSW1000 sub plate shouldn't be used in the LSiW due to the impedance differences.
    Polk does not recommend you use (or sell) PSW1000 plate amp to use with LSiW sub coz the difference in the sub driver impedance and configuration (series or parallel).
    If you have LSiW, you need to use the aftermarket plate amp such as the ones from Parts Express but you need to modify the enclosure a little bit. Or you can seal the back of the plate amp area with MDF and put a couple of binding posts to run with external amplifier which is cheaper and better than the plate amp.
    As far as I know, Polk never sold the passive PSW1000. What you've seen is the LSiW that Polk no longer sold them for a very long time. I don't know PSW1000 is discontinued right now but you can still order PSW1000 from many online retailers and buy one from Polk Direct on eBay while they still have it.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    edited May 2009
    Mega, that's the one I was thinking of............see I told you someone would chime in and correct me if I was mistaken :)
  • dpowell
    dpowell Posts: 3,082
    edited May 2009
    I always wondered if the LSiW was made specifically to be timbre matched with the LSi series speakers? I understand the the amp problem was a driving factor for the recall but why the change of drivers in the PSW1000? Just curious.
  • megasat16
    edited May 2009
    I believe the term "timbre matching" has more to do between speakers. The subs are more like adding the flavor to the speakers and timbre matching does not apply for it. Therefore, you can use any good sub with LSi speakers and vice versa (any speaker with LSi speakers).
    Having said that, PSW1000 and the LSiW subs are meant complement the LSi speakers and I think they do well at that.
  • bknauss
    bknauss Posts: 1,441
    edited May 2009
    dpowell wrote: »
    The biggest change was the impedance capabilities of the amp. If I remember correctly, the PSW1000 amp was able to drive higher impedances at the same power levels compared to the LSiW.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • dorokusai
    dorokusai Posts: 25,661
    edited May 2009
    megasat16 wrote: »
    Great post.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited October 2009
    So anyone see that these enclosures are for sale for $50 a pop. Anyone got a reason why I shouldn't buy two, seal them up and run them as passive subwoofers off my ADCOM 5500?
  • kcoc321
    kcoc321 Posts: 1,788
    edited October 2009
    Where did you see them for $50 each!!! Link please
  • everpress
    everpress Posts: 862
    edited October 2009
    kcoc321 wrote: »
    +1, ****...
    ? Harmon Kardon AVR 55 (dead; replacing with Onkyo TX NR-616)
    ? Polk RTA 11TL's (FR and FL)
    ? Polk TSi200's (RR and RL)
    ? Polk CS10 (Center)
    ? Polk PSW-350
    ? Grado SR-60i Headphones
    ? Fii0 E5 headphone amp
    ? iPod touch (8 gig)
    ? iPod Classic (80 gig)
    ? Mac Mini (as media server)
    ? xbox 360
  • JohnLocke88
    edited October 2009
    http://sandiego.craigslist.org/csd/ele/1410509659.html
    Just a heads up, almost all of the ones I saw had some scuffing, so don't expect a perfect cabinet...
  • megasat16
    edited October 2009
    I think LSiW uses subs with DC Resistance of 2 ohms. If you run them in series, you would have 4 ohms for each LSiW. They will sucks serious power and your Adcom 5500 may not have enough current to run them at 4 ohms.
    Forget HT sub and think Car Subwoofer boxes!
  • JohnLocke88
    edited October 2009
    megasat16 wrote: »
    Was thinking that too; we'll try HT first, if no worky, then car subs...
  • ViperZ
    ViperZ Posts: 2,046
    edited October 2009
    As long as you will drive your 5500 with sub output of the receiver or use the passive sub crossover, you should be just fine.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • JohnLocke88
    edited October 2009
    ViperZ wrote: »
    Yah, subwoofer pre out on the Onkyo receiver, into a Y splitter, into the in jacks on the amp
    and then the speaker cables into the back of the subs....
    Only "draw back" i see is that all sub control will be on board on the receiver...
  • kcoc321
    edited October 2009
    Shoot ...how about a group buy????
    they have them by the pallet (16) for $500..that's $31 each plus shipping of course...
    Aside, How many wpc is the 5500?
  • mmadden28
    mmadden28 Posts: 4,283
    edited October 2009
    I bought one of them last year as a project---if I recall from eBay. I think it was about $100.
    I also bought a Dayton 1000w Plate amp from parts Express (I think eBay as well??), but I never got around to routing it out the box to fit the new amp-I've just been using it as a PJ stand recently.
    One day....:o
    Pool: Atrium 60's/45's
  • megasat16
    edited October 2009
    GFA-5500 puts out 200WPC @ 8ohms and 350WPC @ 4ohms. It's a good amp but it is not made to drive subwoofers all day long and everyday. If you don't crank up LFE too much, it may works well for you. But who don't need a louder and deeper bass from a sub?
    If I were you, I will just buy higher power subwoofer pro-amps which can do around 500-600wpc into 4 ohms or subwoofer amps. They will be cheaper and more reliable for subwoofer operation too. I am not just saying. I've been there, done that, and I don't like too much using 400WPC @ 4 ohms amp. But YMMV.
  • jblincow
    jblincow Posts: 1
    edited March 2011
    Hi, I bought one of those LSiw inclosures and put a PSW1000 amp in it.
    the guys at Polk support told me to give it a try and it works fine so far for three months now.:smile:
