Subwoofer feedback
oledesma7
oledesma7 Posts: 3
edited June 2010 in Troubleshooting
I have an RM6750. I love it but every once in a while I'll get feedback from the subwoofer, even when it's not in use. What could be causing it?
Post edited by oledesma7 on
    nooshinjohn Posts: 25,460
    edited May 2009
    are you running an rca to connect it to the reciever? If so, one of the connectors could be damaged or there might be a short where the rca plugs into the sub. I had this happen to me and it when away with a new cable. could also be just a loose connection as well. Good luck and welcome to CP
  • oledesma7
    oledesma7 Posts: 3
    edited May 2009
    I'm using a Dynex Subwoofer cable. I checked the connections,which were fine, and even switched the cable around, but still have the same problem. Could it just be the cable?
  • oledesma7
    oledesma7 Posts: 3
    edited May 2009
    Switching it off works, of course, but then I'll lose the bass if it's in use e.g. watching a movie, listening to music. Some times it happens in the middle of the night after I've gone to sleep.Sounds like a loud constant bass note.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2009
    yep, these guys are right on the money, i have 2 PSW10's and My RCA connector was damaged, it caused all kinds of hate and discontent.:p
    Once I pulled the Wally World RCA cable out and ordered a halfway decent one from Monoprice I was back in business.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • bassfann
    bassfann Posts: 151
    edited May 2009
    it sounds like the cable is bad
  • gslrider
    gslrider Posts: 1
    edited June 2010
    I realize this is an old thread, but I just started having the same problem with my sub as oledesma7 did. The only difference is that I've unplugged the sub from the receiver, and the only thing that's connected is the power cable. It was fine the night before, and when I woke up I can hear a loud low rumbling/humming sound coming from the sub.
    So I don't think it's the RCA cable. Could it be something inside the sub causing this? From anyone's experience, does this sound like something I can open up and fix myself, or do I need to send it in for repair. Or maybe it just needs to be replaced?
    Thanks for any input.
