Avr hk 3550hd
bdtae5656
bdtae5656 Posts: 235
edited April 2009 in Troubleshooting
Question for the experts...Am I getting all of the Watts that Im paying for from my AMP? I've been told by some that certain AVR's wont allow a amp to send out all of its watts. Is that true in my case???
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Post edited by bdtae5656 on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited April 2009
    Hello,
    The only problem I could see would be with the available output voltage of the pre-amp section, of the H-K, might not be sufficient to drive the power amp to full output. Look at the input sensitivity, of the amplifier, it should be 1.5 Volts or maybe 2.0 Volts. Then see if you can tell what the output capability of the pre-amp section of the receiver. As long as the output voltage is at least close to the input sensitivity you should be fine.
    Regards, Ken
  • thuffman03
    thuffman03 Posts: 1,325
    edited April 2009
    Have you looked at weather you have good power from the wall. A low voltage can cause a system to sound weak. A power conditioner would help if you find that to be a problem.
    Though most AVR's power rating can be confusing. Some say all channels driven and some say two or even one channel driven. From what I found most AVR's never power speakers as well as an external amp. Now if you go out and buy a top of the line $2000 to $3000 avr that might not be the case but the HK's that I have had and others that I have heard sound okay but I don't think the power is there.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • bdtae5656
    edited April 2009
    Hello,
    Regards, Ken
    THsi is my INPUT SEN: Input Sensitivity/Impedance, Linear (High-Level) : 200mV/47k ohms
    Translate please???
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • bdtae5656
    edited April 2009
    bdtae5656 wrote: »
    Translate please???
    Seven-Channel Surround Modes, Power per Individual Channel :
    Front L & R Channels : 75 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
    Center Channel : 75 Watts @ <0.07% THD, 20Hz – 20kHz into 8 ohms
    Surround Channels (L & R Side, L & R Back) : 75 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
    Signal-to-Noise Ratio (IHF-A) : 100dB
    Surround System Adjacent Channel Separation :
    Dolby® Pro Logic® I and II : 40dB
    Dolby® Digital : 55dB
    DTS® : 55dB
    Frequency Response at 1W (+0dB, –3dB) : 10Hz – 130kHz
    High Instantaneous Current Capability (HCC) : ±35 Amps
    Transient Intermodulation Distortion (TIM) : Unmeasurable
    Slew Rate : 40V/µsec
    FM Tuner
    Frequency Range : 87.5 – 108.0MHz
    Usable Sensitivity : IHF 1.3µV/13.2dBf
    Signal-to-Noise Ratio : Mono/Stereo 70dB/68dB
    Distortion : Mono/Stereo 0.2/0.3%
    Stereo Separation : 40dB @ 1kHz
    Selectivity : ±400kHz, 70dB
    Image Rejection : 80dB
    IF Rejection : 90dB
    AM Tuner
    Frequency Range : 520 – 1720kHz
    Signal-to-Noise Ratio : 45dB
    Usable Sensitivity : Loop 500µV
    Distortion : 1kHz, 50% Mod 0.8%
    Selectivity : ±10kHz, 30dB
    Video
    Television Format : NTSC
    Input Level/Impedance : 1Vp-p/75 ohms
    Output Level/Impedance : 1Vp-p/75 ohms
    Video Frequency Response :
    Composite and S-Video : 10Hz – 8MHz (–3dB)
    Component Video : 10Hz – 100MHz (–3dB)
    HDMI™ : Version 1.3a with 10-bit Deep Color
    General
    Power Requirement : AC 120V/60Hz
    Power Consumption : 118W idle, 890W maximum (7 channels driven)
    Unit Dimensions :
    Width : 17-5/16" (440mm)
    Height : 6-1/2" (165mm)
    Depth : 15" (382mm)
    Carton Dimensions (W x H x D) : 21-7/8" x 10-1/2" x 18-5/16"
    (555mm x 266mm x 465mm)
    Unit Weight : 31.5 lb (14.3kg)
    Shipping Weight (System, Accessories, Packing) : 36.7 lb (16.7kg)
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • [Deleted User]
    edited April 2009
    Hello,
    That is the input sensitivity of the H-K not the Emotiva, you want to look at its specifications.
    From looking at the H-K information they don't indicate what their pre-amp output is. You might have to call H-K to find that.
    Regards, Ken
  • bdtae5656
    edited April 2009
    Both webpages and manuals dont have that info...guess I'm going to have to wait until they open back up in the am.
    Thanks Swauger for your help
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • [Deleted User]
    edited April 2009
  • bdtae5656
    edited April 2009
    HK's email says has a standard 1.73 volt pre amp output voltage
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • bdtae5656
    edited April 2009
    EMO emailed me back as well they said "1.25 volts to full output....so what does this all mean??? Anybody
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    Edit: just read your post.
    The HK has more than enough to get max power out of your EMO.
    Ben
    Ben
  • bdtae5656
    edited April 2009
    http://emotiva.com/manuals/XPA-3%20Amplifier%20Manual.pdf
    The manual isnt very detailed like most
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
