Flickering Display on Cambride Audio
zombiemusic
Ok people I need your knowledge once again. Less than a month ago I bought a Cambrige Audio CD player Azur 640c Version 2 from Decibel Audio in Chicago, and today I noticed that the display was dim. I tried changing the brightness, but instead of three steps it did only two, dim and off. The display flickers from time to time, just as flourescent (I know I spelled that wrong) light bulbs do as they are dieing. Now I am going to return the player because for the money and time everything should be perfect.
My question has anyone had a similar expierience with Cambrige Audio equipment? I just want to know, because I love the sonic performance it gives me. But if they are prone to technical trouble I think I will go with another brand.
Thanks again, you help to make my life sonically better!
My Gear
Phase Linear 4000 preamp
Cambridge Audio Azur 640c v.2 CD player
Dual 1219 Turntable
Two Harman Kardon Citation 16 amps
Monitor 50 speakers Bi-amped...
(dieing to upgrade to rti A9)
KLH Tremor Series sub (10 inch 125 watts)
Dual 1219 Turntable
Post edited by zombiemusic on
Between my girlfriend and I, we have 5(from 540 to 840 series) products from Cambridge and never had a problem. Contact your dealer, they should take care of you.
Btw, one thread on the subject should be enough."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Face,
I appologize for the multiple posts. I did not know exacltly where to put it. Also, I know I read only certain catigories in the forum, because of personal interests. So, I was hoping to get the most diverse answers, I guess. Again my appologies.My Gear
Dual 1219 Turntable
KLH Tremor Series sub (10 inch 125 watts) -
No sweat, I hope everything works out for you."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks!My Gear
Dual 1219 Turntable
