LSiC speaker defected???
cabose
cabose Posts: 2
edited May 2009 in Troubleshooting
I have a LSiC centre speaker and when I would have it set up with my other LSi speakers it would always sound like all the sound was projected more from the right side of the room, instead it being distributed equally. I then went close to the centre speaker and noticed that the right cone is projecting a lot more sound than the left cone! Is this normal or is my centre speaker faulty?
Thanks in advance!
Post edited by cabose on
  • Face
    Face Posts: 14,340
    edited April 2009
    It's normal.
    Taken from here: http://www.polkaudio.com/homeaudio/lsi/index.php?s=lsic
    Cascade Tapered Array
    Cascade Tapered Array is an advanced crossover configuration providing wider dispersion and greater midrange accuracy on multi-driver speakers. It's only used on higher end speakers. Your mids will sound more natural and every seat will hear spectacular sound. Pretty neat?
  • tcrossma
    tcrossma Posts: 1,301
    edited April 2009
    It's normal that sound is only coming from one driver at a time due to the cascading design, but the drivers are only a few inches apart and they are not directional, so I don't see how it could throw sound to one half of the room louder than the other. Just a guess, but maybe your room is affecting the sound and you might need some treatments? You could also try moving the center speaker a bit -- a few inches can make a big difference in any speaker placement.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Systems
    Systems Posts: 14,873
    edited April 2009
    cabose wrote: »
    Thanks in advance!
    According to the schematic both woofers operate in the bass range but only one covers the midrange,so I suspect it is the right one thats covering the wider frequency range,thus the difference you are hearing between them.
    Testing
    Testing
    Testing
  • cabose
    cabose Posts: 2
    edited April 2009
    Thanks for all the help guys, makes sense now I have no need to worry.
  • woweu2006
    woweu2006 Posts: 68
    edited May 2009
    LSIC is like nothing else. lol
    Sony BRAVIA W-Series KDL-52W4100
    Polk Audio LSI15 - Front
    Polk Audio LSIC - Center
    Polk Audio PSW10 - Sub
    Polk Audio R50 - Surround
    Playstation 3 80GB - Blu-Ray Player
    Denon AVR-989
    Denon 758
    http://californiammo.com/
    :D:D:D:D:D:D:D:D
