DSW PRO 600 won't turn on
ryanjoachim
So, last night I was watching a movie. Sub was working great, no issues.
Wake up this morning and go to watch a movie, and I can't get it to turn on. I tried unplugging it and plugging it back in, tried changing the volume to see if it would react...no go.
The whole living room is hooked up to 1 breaker, so the plug shouldn't be an issue, but i'll try a different plug.
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
Hello,
Is the LED illuminated on the back? I think those subs have an AC fuse that's part of the power plug socket. If you take out the IEC AC power cord and look at the socket, there should be a small door that drops down and has the AC fuse.
Hopefully a new fuse will get you going.
Cheers, Jed -
There is no light on the back...Does anyone know the standard warranty on Polk subs? I bought this last year, and I have all the paperwork stashed somewhere."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
Left the sub unplugged for around 15 minutes, then tried turning it back on. No lights, no sounds or anything. Tried switching from "Auto" to "On", no lights or sounds."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
Should be under warranty if you bought it last year. Unless you buy used or refurb or from unauthorized sellers, I think Standard Warranty is 3 years for most subs. Some have 5 years though.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Is Frys an authorized seller?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
YES! Absolutely! Find your paperwork and contact Polk to get a replacement or technical support over the phone.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
So, I switched out the cable for a standard computer power cable, and it worked.
Switched back in the original cable, and it worked again.
Out of curiosity, would pushing the sub pretty hard cause it to auto-shut off?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
So, the sub keeps shutting off by itself. I have to unplug it for 30 minutes or so each time before it'll come back on.
Is this an issue of bad power? I've been pushing it harder than normal lately, but the last time it shut off I had the volume down low enough that I could hardly hear it."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
