Tweeter/Driver Replacement Question
No3pencil
Long time Polkie, 1st time poster.
I just recently purchased CS250S Center Channel for $20 (I really wanted the 350ls, but is too large for the space i need it in) 1 of the drivers is blown out and so is the tweeter.
My current set up involves:
CS-250S
RT-12s Front
RT-3s Rear
PSW-50 Sub.
I plan on replacing the SL5001 Tweeter with the same one.
Is there a better set of Drivers to match my set up or should I just stay with the MW4801? Thanks!
http://www.polkaudio.com/forums/showcase/view.php?userid=95490
CS-250S
RT-12s Front
RT-3s Rear
PSW-50 Sub.
Post edited by No3pencil on
might switch out all my sl5501s (5) for tri lams. Anybody have a second opinion on that?
Stay with the stock tweeter. I used to believe that an 8ohms tweeter was an 8 ohm tweeter, and a 43 was a 4, but XO's are not that simple. Stay stock unless Polk recommends differently. Call Polk CS they are one of the best.
Ben -
Pencil the tri-lam's are available on e-bay for a very cheap price. I believe 40-45 for both. They are the silver looking ones. I replaced the tweeters on my RT's with them.
The search on e-bay doesn't come up as Polk tweeters. You have to search "tri-lamintate" in quotes, then it will come up.
I did notice a bit of better highs with the tri-lam's.
Plus they look better.
