which wires go where on the RTi6?
arobotar
arobotar Posts: 1
edited April 2009 in Troubleshooting
Hi there,
my treble response died out about a year ago. Polk sent me a new tweeter, but the treble was still gone. They suggested I pull out the crossover to see if there were any problems there -- it looks like it's in perfect condition, but the thought occured to me that perhaps i had reversed the wires on the leads when I connected the new tweeter. So, now I have a green/white wire, and a blue/white wire. Which color goes to the driver? Which color goes to the tweeter? Also, the tweeter has no indication as to which lead is positive and which lead is negative -- does anyone know which is which, and which color wire (the white or the blue/green) to which lead?
THANKS!
tristan
Post edited by arobotar on
    F1nut Posts: 50,823
    edited April 2009
    A quick look inside your "good" speaker will answer your questions.
  • Solumnus
    Solumnus Posts: 48
    edited April 2009
    I replaced the tweeter on my RTi4 a couple of weeks ago. I don't believe you can cross them up, as one wire has a wider spade connection than the other. But definately check your "good" speaker to make sure.
    Toshiba 62HMX85
    Panasonic DMP-BD60
    Xbox 360 with HD-DVD
    Pioneer VSX-9130-TXH-K
    Polk Audio CSiA6
    Polk Audio RTi10's
    Polk Audio RTi4's
    Polk Audio RTi6's
    Polk Audio PSW505
