Testing drivers... an ebay Seller Q&A
Tour2ma
Tour2ma Posts: 10,177
edited February 2003 in Troubleshooting
Looking at a couple separate drivers on ebay. Here's Q&A with Seller:
from Tour2ma
Could you please confirm the condition of the voice coil and cone assembly. Have you applied a music signal to each one to verify that all is working as it should?
from Seller
tested with a c battery. responded as it should as far as i can tell.
Seems reasonable for checking that the cone travels freely in both directions (if check with both polarities), but not a test I would have thought of.
Is this a legitimate, if not exhaustive, test?
More later,
Tour...
Vox Copuli
Post edited by Tour2ma on
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    it must be legit - russ tells alot of peeps to do it
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • hoosier21
    hoosier21 Posts: 4,413
    It tells you if it is COMPLETELY blown or not, but I wonder if it would tell if it was partialy damaged?
    Russ has said to use the battery to check polarity only
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
