Polk MOMO 12" subs not working.
jbcastello
Hi, I ordered some MOMO subs off of crutchfield in febuary. I bought an amp and box from a friend. They were all working find until the other day and then the subs just stopped working all together. both of them. I checked my head unit wiring since I have a factory installed head unit and had to do some custom wiring with a PAC-OEM2. The amp is a song XM-GTR9001 (I hate sony but got for a steal) I checked the fuses, the cables, everything! i thought I figured it out today, but that was incorrect aswell.. I also tried my step brothers infinity amp that doesn't push much power but it pushed enough to atleast get the subs working. For the longest time i thought it was the amp/my wiring but the amps are getting the signal but they're not sending it to the subs.
Any and all help would be nice...
thanks-
Joe
thanks-
Joe
Post edited by jbcastello on
sry last sentenced phrased incorrectly. The signal is not getting to my subs.
You might want to post this in the car audio section in order to get a better responseHOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around -
But to help at all, your sure your amp is on? And if its hooked up correctly and you went an tried that other amp and it worked then it sounds like you definitely have a probably with something in the ampHOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
yes I have a box that has LEDs that flash with the signal, and the other amp also does that. Both amps sent a signal to the LEDs and the one amp flashed. I also tried something where a very serious friend of mine who installs car audio professionally told me to tape the speaker wires on the battery terminals and it hsould make the sub make a popping noise. nothing popped and he said send em back and get new ones. So i called polk up today and told em and they just told me to send em back didn't give me any tips or anything.
