DSW Pro 500
gwheeler47
I have a "new" (5 months old) DSW pro 500 that doesn't want to power up. I turn it on and the LED goes green for about 10 seconds and then goes red. I thought I would check the fuse, but I can't figure out how to access it. How do you access the fuse?
Post edited by gwheeler47 on
How do you have it hooked up? sounds like it's powering up but shuting down for some reason.
It has worked in the past just fine, but now won't power up.
Figured it out. Still doesn't work. Looks like I'll call CS on Monday.
