RM Series II Front Speakers Help
atmman
I have a pair of old RM Series II Shielded Satellite (RMSS-128902) Which I think finally blew out. The sound is crackled and sounds like it is from the main speakers not the tweeters. Is there a replacement speaker I can buy to replace the damaged ones. How do I know which ones to buy. Can I do this or should they be serviced? Are they worth repairing or should I buy new ones?
Thanks,
Mike
Thanks,
Mike
Post edited by atmman on
Do you have any info on them? Specs, etc?
I acquired a pair of them and a matching sub this past weekend as part of another deal and am trying to decide what to do with them. They sound nice. -
You might want to check the other below discussion as other owners might be able to provide you some additional info. http://www.polkaudio.com/forums/showthread.php?p=1048602DARE TO SOAR:
Your attitude, almost always determine your altitude in life -
I received the following email. Hope this helps...
We do have Tweeters and Drivers for the RMII Satellites available .
The Tweeters (RD0438-1) are $35.00 each and the Drivers (RD5001-4) are $60.00 each + S&H.
