Subwoofer making a weird sound
grantjw
grantjw Posts: 1
edited March 2009 in Troubleshooting
I have a Polk psw 650 and all of the sudden it just started making a weird noise. It will power on fine, but then for the first bass signal it will make a sound like, well the best way I can descibe it is the sound speakers make when you mix the polarity of the wires. I didnt change anything and it just started doing that during a movie and now it does it all the time. Any ideas what it is and how to fix it?
Post edited by grantjw on
  • apphd
    apphd Posts: 1,514
    edited March 2009
    You might want to check connections and try a different sub cable, if no progress there and ff you are sure no one changed anything while you were not looking, give Polk CS a call. It sounds like you need them more than anything I can offer.
    Good luck and welcome to CP
