Shoot out: Dynaudio Vs. Tyler Acoutics
Ern Dog
Ern Dog Posts: 2,237
edited March 2009 in Speakers
Intro: I've had my Dynaudio Focus 220's for about a year now and have been about 95% satisfied with them. My only complaint is that I felt they sounded a tad lean when listening to some orchestral music. This motivated me to try something bigger, so I pulled the trigger on Tyler Acoustics Signature System, 2-piece. The bass modules are absolutely Huge and weighing 100 lbs each! Each one has 2- 8" woofers. These Bohemeths made the Dynaudios look like childs play. When I hooked them up to my Audio Zone chip amp monoblocks, I had some problems and found out from Ty that the speakers aren't compatible with chip amps. So this shoot out was done using a McCormack Delux Edition, Power-DNA-1, which is at 180wpc solid state amp. My second issue was that all the bass was loading up too much and over-powering my room. I moved my whole freckin' entertainment system to the other side of the room, which greatly improved the bass issue.
I have to start by saying that the Danes retail new for $3k and the Tylers retailed new for $6k (they're discontined now). In order to make it a fair challenge I used my Velo 15" sub (retails $1800 new) with the Danes to take care of the low end and turned the sub off when listening to the Tylers.
I listened to Sara Mclauchlan- Afterglow live, Tool,- 10,000 days, Vivaldi- 4 Seasons, Coltrane and Hartman, Kd Lang 49th Paralell & Respighi- Pine of Rome.
Results: I found this to be true no matter what I listened to.... The Tylers had a Huge sound that easily filled the whole room with a very tactile experience. The tweeters had excellent extention, detail and resolution which far surpassed the Danes. Although there were a couple instances were the highs sounded a tad too etchy on the Tylers. The Danes tweeters sounded smoother with rounder edges and not as detailed- more polite. The mids is where the Tylers Really shined. They were able to create this 3-D holographic image and the musical notes had a texture to them. I've never experienced this so dramaticly before. They also did an excellent job with separating out each instrument. In comparison the Dynaudios sounded veiled and wasn't able to produce the same excitement. Now the Bass.... The Tyler bass modules are crossed at 40 hz and produce a ton of bass, which is good, because I love bass, BUT the bass sounded a tad too big (even with port holes plugged) and I couldn't tame them, even with different placements. I think bass traps would probably do the trick. Even with this the bass sounded GOOOOD, especially listening to Tool. Overall the bass sounded clean and low and could uses more tightening up. This is where the Danes & Velo combo really shined because they out did the Tylers. The Danes/Velo bass was SUPER Clean, tight and went ridiculously low. This combo seemed to have a quicker and more coherent low end.
The best all around combo was using the Tyer monitors paired with the velo- the best of both worlds. So there you have it! :D
Note: The Dynaudios and the Audio Zone mono blocks are a synergistic match, so the level of resolution and basically everything is improved when switching to this amp. With this combination Vs. the Tyler, its a much closer race, but I'd still give the nod to the Tylers due to their incredible mid-range.
Pics to follow- Ern Dog
Post edited by Ern Dog on
  • Face
    Face Posts: 14,340
    edited March 2009
    I've always found Dyna's to be on the bland side, long live Tylers!
  • Ern Dog
    edited March 2009
  • danz1906
    danz1906 Posts: 5,144
    edited March 2009
    Very Nice Looking system-Great Review:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • mantis
    mantis Posts: 17,207
    edited March 2009
    Ern Dog wrote: »
    Check out the pics.
    sorry Bro but the Dyn's are sexier.
    Dan
    Dan
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2009
    Agreed Dan. I think it's an apple to oranges comparison. The Dane Focus 220's will be my next speaker someday.
    mantis wrote: »
    Dan
  • Early B.
    Early B. Posts: 7,900
    edited March 2009
    Very nice. Those Dyns didn't stand a chance against the Tylers.
    I'd suggest you do some more fiddling with the crossover on the bass modules. I'll bet you can get them to sound as good as the Dyn/Velo combo with a little tweaking.
    Another option is to sell your bass modules to me. BTW -- Do you accept food stamps?
    "God grooves with tubes."
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2009
    Nice write up and great review Ern Dog.
    VR3 Posts: 28,818
    edited March 2009
    Man! This thread made me super* excited about tomorrow!
    I cant wait!
    Thanks for the killer write up and glad that you are enjoying those Linbrooks!
  • Ern Dog
    edited March 2009
    Early B. wrote: »
    I had the same thought. I was trying to figure out how I could hook up the bass modules to the Velo SMS-1 bass management system. Then I could tweak that sucker until my hearts content. I'm getting stuck because the line out on the sms is an RCA connection (which would typically plug into the sub LFE INput.) :confused:
    Another idea was to separate the speakers and keep the the monitors where they are at on speaker stands, then move the bass modules around to different locations for the optimal spot.
    I'd have no idea how to tweak the crossover in the Bass modules.
  • Ern Dog
    edited March 2009
    mantis wrote: »
    Dan
    Ha! I have to agree with you there Dan. The Dyna's are totally sexy! I'd mount them if I could. :p
  • Ern Dog
    edited March 2009
    I cant wait!
    I already know those Super Towers are gonna be Awesome. The monitors alone aren't enough bass, the bass modules are too much bass (at least for our rooms). I bet the Towers will be just Right!
  • mantis
    edited March 2009
    Ern Dog wrote: »
    It's all about sound quality in the end. I'd mount them 2 but if the Tyler sound better , then while I'm mounting them, I'm listening to the Tylers.
    Dan
    Dan
  • phipiper10
    phipiper10 Posts: 955
    edited March 2009
    Nice review.....thanks.
    It's another good confirmation to keep my Tyler's, at least for now. Seems likely going up in cost might be required to find something better.
    SEAS SEAS SEAS
    Regarding the room filling sound and detail...I love it. Sometimes wish I had a slightly larger room as I think this would be more ideal for these Monitors.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • pearsall001
    pearsall001 Posts: 5,094
    edited March 2009
    Nice review. It sounds like you've got two great combo's to choose from. It's all good. They're both winners!!!
