Game Consoles and RPTV
shiznit311
I know back in the day you weren't really supposed to hook up games to rear projection TV's because they may mess up the screen. Is this a problem now. My brother-in-law hooked his PS up to his new 57' WS Sony and he said it's great; but before I hook my gamecube up to my 51' Sony I want to make damn sure it's not gonna cause problems.
I would like to hear the games on my HT, the sounds on the GX game TV I have are good; but I know I'd be blown away by hearing it in Dolby. I just don't want to screw up the TV in the process.
Post edited by shiznit311 on
$3k for my WS..I won't take the chance!
the thing y back in the day you dident want to hook up game concils to projecton tv was beacues they tend to use a static background.and was a caues of burn in. now the thing you have to look out for is displays that stay in the same plave like chanel logos. but the new rp tv actuley will move the immage around so you dont get burn in. you cant notice unless you look fir it and need the grey bars to see it.
Not a problem now-a-days.
It is an a myth that has been carried on and on.
Was it ever a problem - you bet - but are u using an atari 1982 system. Ya that was a problem - now the game screens are just a little bit more active.:rolleyes:
Other than HT, the point of getting a big screen is for gaming. -
I initially had some fears about it, especially since I play so much Madden. It's been about a month now and I have no signs of anything negative, even with the gray bars up so I can look for it.
I have used multiple systems on my rear projection for about 5 years or so now, starting with Nintendo 64 and I did worry at first but now I dont even think twice. I have not had a single problem with any burn-in what so ever. And it really is awesome to hook your system uo to your big screen for the first time! Its hard for me to play on anything smaller now.
Oh yeah, make sure your tv can do split screen picture-in-picture! We hook up 2 x-box's here and do 8-person Halo on one tv. Sweet!
Yes you can damage your rear projection Tv with video games.However taken the correct precautions,you'll be fine.
If you pause and go eat dinner or something,turn the TV off.Tip of the day.Dan
Me and my buds were gonna try you're split screen Halo idea but for some reason it didnt wanna work...............solution.........................there is now a 50" TV sittin next to the 65"er................XBOX on each one=great fun!!!!
Well yeah, I would suppose that would work too!
I know systems are starting to program in methods to prevent burn-in. With my dreamcast, every game that I can think of, if you leave the game idle for more than a couple minutes, the colors will start to cycle and fade. Much like a screen saver for a computer. I don't know if PS2 does it, but I think I remember Xbox doing this.
yes the x box dims the colors alot. but if you dont turn up the brightness on the tv you will not have very much of a problem. and also very the games and game play.
We've sent people to the Moon, why can't we figure out how to prevent RPTV burnin? Personally, I think it should be dealt with and not put up with. You should be lost in the game and not thinking if you're hurting the tv.
It has been delt with. LCD and DLP bigscreens do not suffer from burn it at all. It is just the CRT and Plasmas you need to watch out for. More so in the material you use. If you have a widescreen tv and watch tv 95% of the time (regular 4:3 material) you can get the black vertical bars burned in your screen. Some TV's use a lighter gray bars to help reduce the possiblity though. When I get a new TV it will be DLP or LCD, I just do not want to worry about burn in. With any luck it will be a DLP front projector! Just need the $ to come down some on those guys.
DLP IS DEFINATELY THE WAY TO GO.
THats what Im going to get here in a few weeks i have a small living room so it will be the 50" Samsung DLP but because its only 18 " deep and weighs only 80 pounds it will fit better in here than the 27 " console or the 32 " Proscan...
AND I CANT WAIT TO HAVE MY RTI70's from Polk within the Month too....
Its all coming together for this gamer.HT SYSTEM
H/K AVR 220
POLK CSI 30 Center
Polk R20 REar
Polk RTI70's front -
So long as you don't pause the game for an extended period, (without switching sources), I don't think it would be an issue.Make it Funky!
