PSW150 Rattle/Rumbling noise
Govnah
I have two PSW150s and I have noticed that one of the subs has a terrrible rumbling/rattling noise. I would imagine that the woofer is shot, if so can you replace the woofer and from where and how much.
Post edited by Govnah on
I had the same problem with a PSW 150...read my thread to see how it was resolved:
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=6329 -
My PSW150 Driver had the spider separate from the frame. Had it re-glued to the frame basket with high temp contact cement. Fixed! The sub works fine again.
Cheers!;)RT800 Towers
PSW150 Sub
CS250 Center
Yamaha NS70T Surrounds
Sony STR-985 Home Theater Receiver
Sony SLV295 VHS VCR
Sony CDP-315 CD Player
Sony 35" Television
Mitsubishi DD-6030 DVD Player -
Hi, if you contact us at 1-800-377-7655 normal office hours, eastern standard time, with your original purchase information we can give you more info on what your options are.-Eric
-Polk Audio
