New sub damper spider ring came loose and rattles
lbritt64
lbritt64 Posts: 6
edited March 2009 in Troubleshooting
I bought a set of mm2104 and have them hooked up to the Polk Polk MOMO C500.1 amp. Last week I notice one of the subs had a bad rattle in most songs. I took the sub out of the sealed box and looked at it. Under the speaker cone it has a voice coil cover which has a plastic ring glued to the metal frame of the speaker. I think it's called the Damper Spider ring. The glue has came loose and when I turn the volume to 5 on the alpine deck which is at a low listening level it rattles and if I hold the ring it stops. To me the plastic ring attack to the voice coil cover would not take much to break the glue loose when cranking the power up. Would the Polk Audio MM1040 be a better sub since it's a newer model? The Momo mm2104 is only 2 months old so should I try to glue it back or just return it since it's under warranty?
Post edited by lbritt64 on
  • CRESCENDOPOWER
    CRESCENDOPOWER Posts: 153
    edited March 2009
    Personally, I would stick with a manufacturer that stands behind its products. Polk Audio is not one of them.
    POST #12:D
  • vmaxer
    vmaxer Posts: 5,117
    edited March 2009
    Personally, Polk has been the best for standing behind their products that I have ever worked with...I don't understand you comment??? What happened? Any dealing I have had with them they went far above and beyond!!:confused:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • janmike
    janmike Posts: 6,146
    edited March 2009
    Just a short time visitor trying to stir the pot. Ignore it, as it should be gone soon.
    Michael ;)
    NORTH of 60°
  • lbritt64
    lbritt64 Posts: 6
    edited March 2009
    Crutchfield offered to out trade my momo MM2410 for a set of db1040 would these be better than the mm2410 or should I pay some boot and get the mm1040?
    Toolfan66 Posts: 17,361
    edited March 2009
    POST #12:D
    This tells all, Sorry Club Polk i could not hold back.
  • vmaxer
    vmaxer Posts: 5,117
    edited March 2009
    Seems the shoe fits.......
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
