CS1000P Crossover question - HELP
vmaxer
vmaxer Posts: 5,117
edited March 2009 in Troubleshooting
Can anyone tell me what the yelloe part on this crossover is and where to get one?? It seems to be dead and the tweeter has no output. Shoul I replace with original parts or build a better crossover??
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
  • Systems
    Systems Posts: 14,873
    edited March 2009
    Thats a capacitor and it would be unusual for it to fail.How did you determine it to be the culprit and not the tweeter itself?
    Testing
    Testing
    Testing
  • vmaxer
    vmaxer Posts: 5,117
    edited March 2009
    As far as the tweeter goes, I took one out of another working speaker and it didn't work either. I then checked resistance ibn the "yellow part" since it is on the tweeter path and it was open. I checked on just like it except it was a 9J 100V and it did check out....so I think it is the problem?? I'm cCertainly not an expert here!!
    I can't find anything on this part running the number on gogle?? Where do you get these?? I plan to call Ken at Polk on Monday. I thought I may get ideas here first and maybe an improvment....
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,117
    edited March 2009
    Seems I need more to drink...not very good typing skills at the moment!!!!!!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ESavinon
    ESavinon Posts: 3,066
    edited March 2009
    The crossover should be available. I bought one last year.
    Make sure you mention that you're a polkaudio forum member for a discount plus 2 day shipping.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • vmaxer
    vmaxer Posts: 5,117
    edited March 2009
    Do you recall how much it was?? Would I be better off to build another, I have read about some doing this and improving the sound?? I just want to get it up and going as quickly as possible, but would modify it if it improves??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
