Paradigm cc-350
renowilliams
renowilliams Posts: 920
edited March 2009 in Speakers
Just wonder whether a Paradigm cc-350 center speaker would hook up well with my RTIA5's. I can get a new one never used still in a box here for 150.00 on a local buy and sell. I would obviously have to check it out but just wanted to get some thoughts on using it with my Polks.
"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
Post edited by renowilliams on
  • mantis
    mantis Posts: 17,388
    edited March 2009
    No it will not. it's a completely different sound. If you want a center channel, get the correct matching center to your speakers. If you like the Paradigm, then get the matching main speakers.
    The front 3 are absolutely critical if you want seemless movement from left center and right.
    Dan
    Dan
  • Knucklehead
    Knucklehead Posts: 3,602
    edited March 2009
    I want to tread lightly here and say that I understand the importance of timbre matching...BUT... I have all Polk speakers with the exception of my center channel which is a Cerwin Vega, I think it sounds pretty seamless to me. However Mantis could be right on the money because ive never heard a Paradigm center channel. sometimes ya just gotta go with what sounds good to YOU. Good Luck.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • woodsman10b
    woodsman10b Posts: 408
    edited March 2009
    Timbre matching is important to a degree, but what I have experienced is the fact that many different brand speakers can match up fine in any setup. Ive used a Jamo center that sounded great with my Mirage fronts, Ive used a Klipsch center with a couple different pairs of Polks that also matched very nicely. If you can, audition the Paradigm center with your 5's, adjust the volume level of the center and find where it sounds best to you, then sit back and listen to many different sources. Paradigm makes quality speakers, so it just mite match up with the quality Polks. If you do decide to buy it, let us know how it sounds with your 5's.
    Most of them only hear how loud it sounds, and the rest of us hear everything else - :rolleyes:
