Rt35i Tweeters....
MxStYlEpOlKmAn
How much do these tweeters cost to replace? Well actually...is the RTixxx tweeter better? Because I am looking to replace my current ones sometime because their a tad too 'present' at times.....its annoying...newayz....neone know?
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
I promised myself
Damn you all! - ATC
Post edited by MxStYlEpOlKmAn on
The drivers and crossovers in speakers are designed to perform together. If you change the tweeters you will most likely have a problem with the crossover not matching up with what you put in. However, you may be able to upgrade the crossover in these to match, but I'm not sure about that. You might want to check with Ken in Customer Service. Another option would be to buy a DAC (I presume you're playing cd's) which would most likely smooth out the high end.Political Correctness'.........defined
