PSW150 hum issue
jfiore3
Hi all....
I have a PSW 150 sub with what appears to be a blown driver. The actual symptoms include a low hum during all sound activity. Here are some other details:
-Hum occurs in both polar phases
-Hum occurs through all frequency ranges for sub
-Tried switching inputs
I discovered this problem when it was hooked up to a new receiver. A smaller Yamaha sub is now in its place and works fine (just not powerful enough).
Any ideas?? Thanks!
Any ideas?? Thanks!
Post edited by jfiore3 on
jf welcome to CP. It sounds like you may be dealing with a ground loop. Follow these links for a couple short reads on ground loops and how to get rid of them.
http://www.audioholics.com/tweaks/connecting-your-system/ground-loops-eliminating-system-hum-and-buzz
http://www.epanorama.net/documents/groundloop/ -
I had a similar problem.. I bought a ground loop isolator from Parts-Express.com (Recommended by Ken @ Polk) and it eliminated the problem... Best $10 I ever spentELITE VSX-99 REFERENCE
ELITE PD-65
SDA-1C's with new RDO194-1 tweeters as MAINS
MAGNEPAN TYMPANI 1D's for alternate fronts for classical music
PARADIGM REFERENCE CC-450 Center
MONITOR SERIES II... M10 REARS
2 POLK DSW-600PRO SUBS
"ROCKIN THE HOUSE"
