EMF Question re: Speaker Placement
jgrog
jgrog Posts: 8
edited March 2009 in Troubleshooting
I am getting ready to install two LC265i"s for LF and RF in wall, and a center LCi-C below a 58" Plasma Pani800u HDTV.
I noticed that the LCi's have no EMF shielding, and I only have 35 " between the HDTV and walls. I can keep the Left and Right Front 265s a foot from the TV; however, they are close to the walls.
Should I ABSOLUTELY keep speakers 12" from PLasmaTV and use wall disctance switch, or can I move them closer, or use a light shield material to control EMF?
What kind of EMF is measured off the LCi's?
I have equipment to test EMF; however, I thought that you guys might know approx EMF levels and offer suggestions. I prewired for speakers, but have not cut out holes yet for speakers. I have not mounted HDTV yet either.
Thank you.
Post edited by jgrog on
  • ShinAce
    ShinAce Posts: 1,194
    edited March 2009
    The direction the speakers face will play a big role. Typically, having the speakers pointing straight ahead(like a built-in TV speaker) is the best. So when you have to play with the 'toe-in', have the tv on and watch for any changes in the picture.
    Also, 12" should be enough.
    I'm not sure how susceptible a plasma tv is to magnetic fields. I doubt it would be major, or even noticeable.
  • BrettT1
    BrettT1 Posts: 560
    edited March 2009
    Bucking magnets?
  • Systems
    Systems Posts: 14,873
    edited March 2009
    Unlike CRT's, Plasma's and LCD's are not affected by stray magnet fields from speakers.
    Testing
    Testing
    Testing
  • jgrog
    jgrog Posts: 8
    edited March 2009
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2009
    Like GV said, plasma's and LCD's aren't affected by magnetic interference like CRT's are. You can put the speakers as close as you want to them, you'll be alright.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
