receiver & amps?
chu
chu Posts: 178
edited March 2009 in Electronics
Hi!
I decided to take a plunge to create a two channel setup for my room. I'm mainly looking for opinions on which receiver & amps I should look into. I doubt I will expand more than 2 channels, since I have limited space. I will be using this setup primarily for music roughly 95% music 5% tv/movies. I don't really care for the video processing, up-converting, and etc since my desktop is more than capable to handle those projects on its own.
Thus far I have:
Speakers:
Lsi9
Sub:
dsw micropro 3000
(I picked up both those on the cheap)
What I'm looking at:
Receivers: limit $1000
onkyo 806
Yamaha RX-V863
Denon AVR-2309CI
amp: limit $800
xpa2
rpa2
I would like to have a phono out as well, it would be sweet to hook up my tables to the receiver.
I primarily listen to electronica music, especially live performances if that helps any.
Post edited by chu on
  • metal83
    metal83 Posts: 1,219
    edited March 2009
    The RPA-2 is out of stock and discontinued, so you can rule that one out.
  • Retro152
    Retro152 Posts: 985
    edited March 2009
    chu wrote: »
    Hi!
    Thus far I have:
    Speakers:
    Lsi9
    Sub:
    dsw micropro 3000
    onkyo 806
    Yamaha RX-V863
    Denon AVR-2309CI
    amp: limit $800
    xpa2
    rpa2
    The Xpa-2 is $799 + $25 for shipping, not much over your budget with very favorable reviews.
    Receiver: Pioneer Elite SC-05
    Amp: Emotiva Xpa-3
    Front L/R: POLK Rti-a9s':D
    Center:POLK Csi-a6
    Rear surround's:POLK Rti-a1s'
    Sub: Klipsch Synergy sub-12
    Sony Kdl-46w4100 46" LCD
    PS3
    Audioquest type 4 wiring.
  • tcrossma
    tcrossma Posts: 1,301
    edited March 2009
    I'd be looking into a 2-channel preamp instead of a receiver.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • metal83
    edited March 2009
    Pioneer Elite SC-05 for $899......Amazing Deal!!!
    http://www.valueelectronics.com/
    edited March 2009
    metal83 wrote: »
    That's a great price! If I were in the market I'd have that on my short list. It's also true that if you don't plan to run any more than 2 channel, a good pre-amp may be all you need and you can find some nice used models on sites like Audiogon--which almost everyone here knows well, better than I, in fact.
    Personally, I like Onkyos and if you're not disturbed by possible upscaling glitches on video on the 806...you can get those for less than 699 online. Which makes it a pretty good deal.
    Hope I haven't added to your confusion? I run a Denon AVR2807 and am looking into a 2 channel power amp myself--pretty much for the same reasons you are (a two channel set up so I can run my mains separately with more power). The Denon is rated a 110 watts and does OK, but...?
    cnh
  • chu
    chu Posts: 178
    edited March 2009
    metal83 wrote: »
    bah, 2 months of research gone down the drain lol
    retro152 wrote: »
    Yeah, that is what I'm thinking. A little over is fine.
    tcrossma wrote: »
    Any suggestions? It takes me while to review and research products. Since this is my first time picking out audio equipment for home use. Any help would be appreciated.
    cnh wrote: »
    cnh
    I like the onkyo as it leaves me a path for expansion in the future that is if I can find a bigger place to rent. But I don't really see that as a possibility in the near future. As for the upscaling aspect, I don't really care for it. I rarely watch tv/movies (its been about 2months since I last turned on the tv). However, I will look into denon and the pioneer and will check out audiogon as well!
    Thx for the suggestions guys :)
  • CRESCENDOPOWER
    CRESCENDOPOWER Posts: 153
    edited March 2009
    tcrossma wrote: »
    What he said. Check out Audiogon, E-bay etc.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2009
    I've been using an HK AVR for years as a pre/pro. I've always felt it sounded better than any Pio, Denon or Onk I tried. That said, a buddy gave me a Luxman TP-114 (tuner/pre), he no longer used. For 2 channel listening it's a significant upgrade over an AVR. Neglible noise floor and the overal tonality is a real step up. I'm not recommending this piece in particular, but I think you'll find that there are many used 2 channel pre's that can be had for a song, that will be a better option for you.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • mantis
    mantis Posts: 17,394
    edited March 2009
    metal83 wrote: »
    Crazy as it's a 1800.00 receiver and worth the asking price. Thats a stupid deal for a killer receiver but this is not the right piece for this dude.
    I suggest you look into a stereo receiver or Integraded. Check out Rotel and NAD. They both offer beautiful 2 channel stereo stuff and entry level audiophile sound.
    Dan
    Dan
  • Mike21
    Mike21 Posts: 252
    edited March 2009
    Hi chu
    I don't see why you would need a surround sound receiver like the Onk 806 for 2.1.
    Unless you need a radio tuner, I recommend a stereo integrated amp w/ at least 100wpc power (your speakers are rated up to 200w).
    Its hard to find an integrated w/ a phono input, but you can always use an outboard phono pre (which I think is better anyways).
    You might want to take a look at the Cambridge Audio 840A V2 which Audio Advisor is selling for $1,600:
    http://www.audioadvisor.com/prodinfo.asp?number=CA840AV2
    The Cambridge has a preamp out for your sub and is rated at 200wpc into 4ohms (which is what your speakers are).
    You could pair the Cambridge with the Vincent PHO-11 for $150 at AA.
    IMHO, Cambridge Audio and Vincent are the next level up from Onkyo and Emotiva.
    Let us know what you get.:)
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • chu
    chu Posts: 178
    edited March 2009
    Mike21 wrote: »
    Hi chu
    Wow Mike, you're awesome. I think you found the perfect fit for me. I will be ordering the cambridge once I get paid at the end of the month :D.
  • renowilliams
    renowilliams Posts: 920
    edited March 2009
    chu wrote: »
    Hi!
    Thus far I have:
    Speakers:
    Lsi9
    Sub:
    dsw micropro 3000
    onkyo 806
    Yamaha RX-V863
    Denon AVR-2309CI
    amp: limit $800
    xpa2
    rpa2
    I'm Just wonderring what you think of your RX-V863, I have the RX-V861 and I am happy with it. Is there much difference between the two?
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
    edited March 2009
    Hi Reno.
    The 861 is a nice receiver...What Hi-Fi? Seems to Love the 863.
    Here's the link:
    http://whathifi.com/Review/Yamaha-DSP-AX863SE/
    But I don't think I'd make the move myself. The 861 has some good features/power.
    cnh
