Two issues popped up
NeilGabriel
NeilGabriel Posts: 1,487
edited March 2009 in Troubleshooting
Hopefully, a third won't.
1)The mid on my Monitor 7s just stopped. It is the non-fused model. I have a replacement from an old set of 5s. Interchangeable?
2)I decided to use an old dvd player to play cds through my 5.1 processor. I cannot get sound from the audio optical but I do out of the analogs. Maybe I am forgetting something, but I am certain you can run CD through the optical audio. Oh, there is an amp connected to the processor.
Thanks for help on either.
Mike
Post edited by NeilGabriel on
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2009
    Mike
    Mike, check the menus. There is often an option in 'Audio' menu on the DVD player to change sound output from 'analog' to 'digital' or to optical, or something similar.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • NeilGabriel
    edited March 2009
    ViperZ wrote: »
    Thanks, I was looking for that....right now it is not hooked to a monitor but it does on a screen on board...I just kind find the right selection....thanks...I will look some more.
  • NeilGabriel
    edited March 2009
    My processor is a B&K 20. It has designated optical inputs and they have not been reassigned. SO, I am still at a mystery that the optical connection between the dvd player and the processor does not seem to carry audio while the analog does.
    Any other thoughts? I am certain the cable is good.
