Question on PSW125
gsquared
I keep hearing some strange vibrating coming from the inside of my PSW125 when I turn the volume all the way up (sounds like something is rattling on the inside). Does anybody know if there are guides available for a step-by-step walkthrough of opening and servicing the sub?
Post edited by gsquared on
I would guess that right there is your problem.
The PSW125 is a decent little sub for what it is, but it's not an end all sub that you can drive to the moon and back. Any sub is going to rattle like that when it get's turned up to much. Roll back on the volume a little bit.
It is possible though that there's something loose in there rattling around too of course.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I owned the psw 125 for months with no rattle. Try taking the amp plate off and see what's inside.
When you say, "turn it all the way up", are you just referring to the gain on the sub itself, or the volume on your AVR?
Like Lee said, take the amp off and check inside. The plate should remove easily enough.The nirvana inducer-
