Pioneer Elite MCACC and power amps
disneyjoe7
disneyjoe7 Posts: 11,435
edited February 2009 in Electronics
If you are using MCACC for your normal HT settings, but used Pure Direct for 2 channel modes are you still using MCACC setting levels? The question comes about with the use of extra power amps used for the front L / R speakers. Is the MCACC placing the front L / R levels to a heavy turned down setting to adjust for the amps in balancing center / rear surround speakers. I could see it doing that, but I would think Pure Direct would have bypassed this in it's mode no?
By using the receiver in this mode of 2 channel / HT is it best to manually set MCACC for the front to place it at 0db and force the center and rear surrounds to a higher db setting to balance out the sound?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
  • mantis
    mantis Posts: 17,448
    This is a good question. I don't know the answer but I can find out for yeah.
    Pure direct shuts down video and unused circuits from what I understand so you have a pure audio signal. Mcacc is a calibration. I don' see why it would turn off it's settings. Your speakers get calibrated to the room which is something you would want on even in pure direct. Think about it. But I don't know exactly what's going on there.
    Dan
  • Montoya
    Montoya Posts: 506
    Try putting your receiver on stereo mode and turning off mcacc for two channel listening I found this works best for music in my setup.
  • disneyjoe7
    Dan, see your point on room settings as for as eq but sound levels in a 2 channel mode. But to be fair my old Onk did the same thing not MCACC but for sound levels needed to keep the L / R levels at 0db and raise the center, and rear surrounds channels so the pure audio mode worked at 0db.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    Montoya wrote: »
    I thought the Stereo mode sounded like the Worse thing I ever heard in my system when I did it. It was going to getting $$$ if it sounded like that I was happy that day. :(
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
