Faulty amp?
Nospheratu
Nospheratu Posts: 14
edited February 2009 in Troubleshooting
Hi guys,
I have this weird problem that has me baffled. I have a polk momo mm2104dvc sub which was powered by my c300.2, no problems whatsoever.
Ive recently acquired a c500.1 to power the sub. I did a straight swap between the amps and all is fine... When the headunit is on. When i turn the headunit off the sub makes a sound increasing in loudness ending in a extremely loud pop. This repeats continuously until i turn the headunit on.
There doesnt need to be any music playing or any volume level set on the headunit. It simply needs to be ON. As soon as i turn it off the symptom reappears.
Im using speaker level input as the stock headunit does not have a line out. The ground has been checked. The remote lead is connected to the vehicles accessory lead.
I have swapped the amps back ie. Connected the c300.2 to the sub and i dont experience this. It only happens with the c500.1
Any suggestions/help would be highly appreciated as I am at my wits end.
Post edited by Nospheratu on
