New Epik products
Ron Temple
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
Post edited by Ron Temple on
Most impressive!!! I really like the Dynasty..so now we know what Epik has been up to...:D
The wait is finally over
hmm....18" sealed dragon sub...
wonder what 4 of those will do...:Dmy 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Is that the 18 inch conquest woofer in
Dragon
Phoenix
Dynasty -
i dont think so...when i had the conquest, i remember the cone is not curvilinear....
also the conquest has a foam type surround...the new driver has a rubber surroundmy 7.(1x4) HT setup
Buttkicker
Rubber is going to be better -
Awesome!!!HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Obviously, these new subs have been in development a long time. I've spoken to Chad a few times over several months and knew they were coming. From what he tells me, the sealed 18" is an awesome sub and very tempting at a grand. Mainly, he wanted to shrink his line in terms of size and still offer stellar output and sound quality. I wouldn't be adverse to shrinking my footprint to a 20" cube. If I make the plunge, I'll let you guys know how it sounds.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
when i got the conquest, i spoke to chad asking him about the durability of foam surround, he told me that they are treated with uv protector and has a 7 yr warranty iircmy 7.(1x4) HT setup
Buttkicker
Ron Temple wrote: »Obviously, these new subs have been in development a long time. I've spoken to Chad a few times over several months and knew they were coming. From what he tells me, the sealed 18" is an awesome sub and very tempting at a grand. Mainly, he wanted to shrink his line in terms of size and still offer stellar output and sound quality. I wouldn't be adverse to shrinking my footprint to a 20" cube. If I make the plunge, I'll let you guys know how it sounds.
how big is your listening room?
after going sealed, i dont think i will go back to any kind ported sub...only exception is the danley tapped horns
my 7.(1x4) HT setup
Buttkicker
I got first dibs on your HSU's.:D -
Ron
Do you know what his stock is like? Are these subs 4-5 weeks like before. -
The room is 2000 cube with a 5' opening into another 5500. The way the rig is oriented, the room acts more like a sealed room than not. A single Ultra13 or that new Dynasty are more than enough. I've played around with sealed in the past when music wasn't a priority. Now that it is, I no longer use the sub except during concerts or DVD A/SACD MCH (which I'm listening to less). So the sub's been relagated to 95% HT duty. I'm more than satisfied with the Ultra, but I sure could use the floor space/additional placement options with the smaller footprint.how big is your listening room?
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
That Dragon w/ the XLR inputs would match up REAL nice with the Emo RSP-2 Pre/ Pro.
I'm glad they're back. I was thinking they were gone for good.
BTW, has anyone had a chance to hear the Emotiva ERT 8.3 Ref. towers?I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Oops, I meant the Dragon, not the Dynasty.Ron Temple wrote: »The room is 2000 cube with a 5' opening into another 5500. The way the rig is oriented, the room acts more like a sealed room than not. A single Ultra13 or that new Dynasty are more than enough. I've played around with sealed in the past when music wasn't a priority. Now that it is, I no longer use the sub except during concerts or DVD A/SACD MCH (which I'm listening to less). So the sub's been relagated to 95% HT duty. I'm more than satisfied with the Ultra, but I sure could use the floor space/additional placement options with the smaller footprint.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
i have a 4 ib 18 in setup and all i can say is hope you brought your depends hahahahahaha
Wow! I thought I had my mind set on a couple SVS PC13's, but now it looks like the tables have turned to a couple Dragon's instead. The footprint is almost perfect for my situation, plus I dont have to look at a "water heater looking sub" in my living area either. I'm sure these subs sound fantastic, just need the reviews to start rolling in...
Ron,
I'd love to hear a comparison with your current PB13 to one of these! I'm almost thinking the 18" will deliver more goods than the SVS, we'll see... -
I haven't talked to Chad about this, but my feeling is that the shallow rolloff of the sealed 18" will provide room gain that will deliver very deep extention similar to a Submersive or the Hsu ULS 15 (even without the moving filter) with even more output. He did tell me that his prototype was able to get 124dbs max output within the meat of it's range. The amp on the prototype was rated at 1250w, 2500 peak, so the production model might not quite have that kind of top end, but hell yeah, I think it's going to be a monster performer.Wow! I thought I had my mind set on a couple SVS PC13's, but now it looks like the tables have turned to a couple Dragon's instead. The footprint is almost perfect for my situation, plus I dont have to look at a "water heater looking sub" in my living area either. I'm sure these subs sound fantastic, just need the reviews to start rolling in...
Ron,
Due to the price, I could afford to do a comparison between the Ultra13 and the Dragon and flip the loser. It's an interesting idea. It's something I'll consider, but due to my current usage, I'm just not sure. I really like the Rosenut finish on my SVS
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
....the XLR inputs would match up REAL nice with the Emo RSP-2 Pre/ Pro....
noob question; what are XLR inputs (where/how are they used, etc)? -
Chameleon2 wrote: »noob question; what are XLR inputs (where/how are they used, etc)?
XLR on the left, RCA on the right. XLR's offer a better signal than RCA's.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
they came back hardcore too, nice site upgrade to boot. Its good to see them back, though I own SVS stuff. I'd love to experience a dual Conquest setup.Shoot the jumper.....................BALLIN.............!!!!!
Ron Temple wrote: »I haven't talked to Chad about this, but my feeling is that the shallow rolloff of the sealed 18" will provide room gain that will deliver very deep extention similar to a Submersive or the Hsu ULS 15 (even without the moving filter) with even more output. He did tell me that his prototype was able to get 124dbs max output within the meat of it's range. The amp on the prototype was rated at 1250w, 2500 peak, so the production model might not quite have that kind of top end, but hell yeah, I think it's going to be a monster performer.
I'm sure the sealed Epik won't dig as deep as the Ultra, it's difficult to hit the low octaves with a small enclosure. However, I'm sure if I got an Epik sealed quad set-up, I wouldn't have an issues with that either.:) I would also like to see a shoot out with HSU ULS-15 and the Epik Dragon. I'd have to bet that the Epik has more output, but question the musicality of the large 18" woofer. We'll see... Craigsub over at AVS needs to get his hands on these! -
Wow:eek:
2 Vanquish up front, put my 2 Sonys in the back. Bring on Cloverfield!:p____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
Soon as I sell my MP4K that Dynasty will be mine.
Those look very nice! The Vanquish and the Sentinel are now both in the running for the sub for my HT setup. I've been leaning mainly towards an SVS PB-12NSD, but those two both look even better. They cost a little more...but it could be well worth it.
I've got plenty of time to decide anyway I suppose.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »Those look very nice! The Vanquish and the Sentinel are now both in the running for the sub for my HT setup. I've been leaning mainly towards an SVS PB-12NSD, but those two both look even better. They cost a little more...but it could be well worth it.
I was wondering where you were. I thought maybe you started your one year prison term for one million dollars.:) -
They actually already gave me the million dollars, I'm serving the prison term right now. They let me bring my computer and my stereo rig with me, so I'm all good.;)
Come visit me in my prison cell sometime if you're feeling bored...lolThe nirvana inducer-
Ron,
Here is the response I got directly from Chad himself.
Hello Mike,
Thanks for your email. Your question is similar to what many others have sent to us. The Dragon is first and foremost designed for sound quality, but it is very capable.
The immediate thing to make clear is that sealed subwoofers do not share the same output advantage as ported subwoofers. It is always more expensive to make a sealed subwoofer loud than a ported subwoofer. It is just physics.
That being said, the maximum output capability of the Dragon eclipses both the Hsu ULS-15 and the Velo DD-18 at any frequency by a noticeable amount. I have owned and measured both so I can comment directly. Considering that is smaller than the DD-18 and costs 1/5th as much, that says a lot.
The sound quality is of course a much harder thing to describe since bias always comes into play. In regards to our own subwoofers, I think the Dragon is our most musical subwoofer to date, but it will not have the sheer output capability of a larger ported version for example. Still, it has a ton of slam and power during bass heavy passages.
The Dragon's sound quality is a direct result of it using such a large cone surface area. We could have used a 15 inch driver to do the same thing by increasing excursion capability, but the 18 beat out the 15 relatively easily in distortion with less power and it costs less. Its cone always moves less to create the same amount of output, and the result is a very effortless sound.
Another option is to purchase a Phoenix and plug up the ports. That way you get a larger cabinet and more low end, but always have the option for a ported design should you want more output in the future.
Please let us know if you have any other questions.
Thanks again for your email and your interest in Epik Subwoofers.
All the best,
Chad -
Are any of their new subs available or do you have to order and wait?Speakers: SDA-1C (most all the goodies)
They look readily available to me. Might want to call and ask.
