Neighbor calling about music
Vette C6.r
Vette C6.r Posts: 1,560
edited February 2009 in Speakers
Hey guys. Odd question. My neighbor called and told me that "her house was shaking" from my music.
I live in a single family house and the neighbor is aprox. 30 feet away from me.
After being amazed that she could hear my music I was a bit pissed that she called when I'm in my house doing something I enjoy.
I have a Polk LSI system with two PSW 150's that seem to be creating the problem.
Is there any cheap way of "deadining" the sound. She claimed that she could hear the music but it was the bass that was annoying her.
Any ideas so that I don't piss the neighbors off ?
TK
Post edited by Vette C6.r on
  • nadams
    nadams Posts: 5,877
    You could hang your listening room with QuietRock sheetrock. But that's expensive.
    My biggest suggestion is turn it down or move out of town. I've come to face the fact that I don't live in the middle of nowhere anymore, and therefore have to be somewhat courteous to my neighbors.
    Ludicrous gibs!
    treitz3 Posts: 19,992
    QuietRock will NOT stop lower frequencies, I know. I just installed an entire side of a TH with it and the lower registries were not affected. Vette, I have to ask. What kind of gear are you running?
    I ask because I live 6" away from two neighbors, without QuietRock and I have yet to get any complaints. I do play it rather LOUD as well. :D
  • thsmith
    thsmith Posts: 6,082
    Probably coming from your subs, try something like a subdude. Is you house a concrete slab or pier and beam ?
  • Vette C6.r
    I have Polk LSI 15's, LSI center, rear RT1000's and side RT 5's. I have double PSW 150's. Powered by a Pioneer Elite 94.
    I do play it rather loud but all my windows are very new and the basement is a concrete foundation.
    I relieze that bass has a weird way of transmitting sounds but I think she was exaggerating a bit when she said that her house was shaking.
    Ideas???
  • Vette C6.r
    What is a subdude???
  • thsmith
  • tcrossma
    tcrossma Posts: 1,301
    turn down the subs, or turn down the music a bit.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
    Are you running with spikes on all of your speakers? You want to decouple the bass from the floor as much as possible.
  • shack
    shack Posts: 11,154
    Or....just crank it up and ignore her.
  • ShinAce
    ShinAce Posts: 1,194
    As a teenager, I was running dual 12" subs.
    In the afternoons, when I had it blasting(depending on the music itself), the neighboors kept expecting a car to roll by. It's only after a while that they figured out it was me with my window open.
    My house was semi-detached and separated by a cinder block wall up to the attic. Despite this, even at very low volumes(like 50-60 dB) the neighboors could clearly hear the bass at night.
    Bass just travels all too well. Nothing you can do except turn it down.
  • kneedragger37
    kneedragger37 Posts: 108
    shack wrote: »
    +1 ;)
    In all seriousness, I live in a single detatched home with 30 feet between myself and the neighbors on either side. I work in youth ministry and will sometimes have groups of 10 or so teenagers playing XBox 360 games at levels higher than most any adult would be comfortable with. And the games will produce lower frequency bass than most music. I have two 12" subs, and my home was built in 1950 with 2x4 construction (as opposed to 2x6 which is what most newer homes use on the outside walls), and the insulation is crappy. There's even a HUGE sliding glass door in the room, which should let some sound out, I would think. I have been standing outside my house with the front door open (glass storm-door closed, though), near the neighbor's house, and the amount of sound I could hear from my house, bass or otherwise, was negligible at best.
    In my opinion, your neighbor with the "shaking house" is either being a little high-maintenance or needs to have her home's foundation checked out. If you want to be super courteous, wait for her to be home, turn your music up, go knock on her door and take a listen for yourself. Heck, don't even tell her the music's up and see if she's even noticed. Is it possible she heard it from outside while taking a walk or parking her car or something, and the power of psycho-acoustics started making her house shake afterward...?
    The whole thing seems pretty far-fetched to me...
  • Face
    Face Posts: 14,340
    Crank your stereo and go outside, standing between your house and hers...see if she's telling the truth.
  • BjornB17
    BjornB17 Posts: 752
    sounds like she is exagerating a bit...
    i watch movies on my HT after work..... i crank it up pretty loud....... actually yesterday i put it as loud as i could stand with an Emotiva UPA-7 and my sub maxed out on back and +7 db on prepamp (just to see how loud i could get everything), and my neighbors who's house is only EIGHT feet away said he couldnt hear anything. Both of our houses are pretty small too.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • metal83
    metal83 Posts: 1,219
    BjornB17 wrote: »
    Yep, some people just get off on complaining.
  • bobman1235
    bobman1235 Posts: 10,822
    Right, a reasonable neighbor would have asked nicely if you could turn it down before resorting to "my house is shaking." This person sounds like a ****.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I would tell her to snuggle up to the wall press her body firmly against it and enjoy the Good Vibrations.
    BTW, All my neighbors are scared of me.
    RT1
  • metal83
    RT1
    Why? Are you blasting satanic music? :eek::p;)
  • shack
    shack Posts: 11,154
    There is a reason he is known as Big Ted...and then there is the gun thing...
  • Face
    Face Posts: 14,340
    shack wrote: »
    He's a big teddy bear? Or does he walk around outside wearing large teddies? :D
  • metal83
    shack wrote: »
    Ohhhh ok, i see.....:eek::D
  • nadams
    nadams Posts: 5,877
    BTW- I wasn't trying to be unhelpful. In fact, as soon as I get out of work, I'll be cranking up some tunes and downing some brews. I'm sure the neighbors will be bobbing their heads along to whatever's coming out of the SDA's.
    Ludicrous gibs!
  • shack
    shack Posts: 11,154
    Now THAT would be scary! :eek:
  • reeltrouble1
    well my neighbors prefer the teddi to the speedo............next fest Lou and I will be color coordinating our loin cloths for the belly buck contest.
    My neighbors now just consider me "eccentric" so I can pretty much do anything and nobody cares. Of course they did meet some of you which explains a few things.
    RT1
  • bruss
    bruss Posts: 1,039
    BASS makes you live longer
  • shack
    shack Posts: 11,154
    So true...one's choice of freinds often has an influece on the opinion of the neighbors. Based on GA PF 07 I'm sure your neighbors are now VERY leery of the Big Ted clan.
  • donedroolin
    donedroolin Posts: 225
    I have had the police called on me. I did not even know they were at the door,nocking with thier flashlight untill a very quiet scene came up. When I answered the door the cops laughed and just said could I turn it down alittle. I have all great neighbors except for the dirt balls to the right of my house. They don't work and are bums. So one day while I was at work I played that song. Get a job you bums you bum ba bum bums, Money dont grow on trees you,well you get it, played it on repeat day. Needless to say they did not like it. The cops said I was not hurting anyone and I was free to play what I wanted at my house. All the while he is trying to keep a strait face. So if it is earlier enough in the day Rock on. Other times so some respect.
    TV- 52 inch LCD SONY BRAVIA XBR6
    TV- 42 inch PLASMA HITACHI ULTRA VISION
    AMP- PARASOUND HALO A-51
    CONTROLLER- PARASOUND HALO C-2
    FRONT SPEAKERS- LSi15's and LSiC
    REAR SPEAKERS- LSi7's
    SUBWOOFER- VELODYNE DD15
    BLU RAY- LG SUPER BLU BH200
    BLU RAY- SONY BDPS350
    GAME SYSTEM- NINTENDO Wii
    MONSTER POWER CONDITIONER
    WIRES- AUDIO QUEST and MONSTER
  • reeltrouble1
    ShackDaddy,
    Of course one of them who came thought it was a "Polka Fest". oh boy, now that would be a site, actually, that might be pretty cool.
    I could give the OP my camel for a couple weeks, he has been a bit ornry though, he ate some poison ivy and spanish moss and now has gas..........but that would at least take the attention off the music.
    RT1
  • Vette C6.r
    I will try the sound test when I get home.
    I agree with the over-sensative part - just trying not try annoy them.
    I will try to isolate the woffer with some floor spikes or the like.
  • hearingimpared
    hearingimpared Posts: 21,136
    RT1
    uuuggggghhh I have to wash my brain out with bleach!:D
  • hearingimpared
    I'm with Shack, ignore her.;)
